roaniecowpony
My front Rubicon D44 M210 locker actuator quit working about 2 years ago. I immediately found out that Jeep didn't sell the locker actuator or even the whole differential carrier with the locker assembly. I had to find a fix.
Yes, you can put in ARB or Eaton or OX lockers. Those locker differential carriers are expensive on their own at $1100 to $1500 depending on which you choose. But that's not the whole nut. All three of those locker differentials require the installation of 35 spline (vs OEM 32 spline) axles which will run you another pile of $100 bills.
Since I had put in chromoly axles in my front and rear axles and preferred to keep them (with the FAD operational) I searched for a replacement locker actuator coil solution using the OEM differential. After much research and purchasing of various parts, I determined that the Bronco Raptor used a D44 Advantek platform axle. I then found out that the Bronco differential carrier was the identical subassembly part. From there, I found that the Bronco locker actuator coil was similar but lacked the mounting for the sensor that Jeeps use. Dana Aftermarket sold parts for the Bronco, but not the Jeep Rubicon lockers. So, I bought the Bronco locker actuator coil and related parts to see if they would work to replace my jeep parts. They do work, as this thread will show.
I finally found a window of opportunity to replace the front locker coil actuator in my JLUR. The weather in southern California has been hotter than a two dollar pistol. But it really broke down a lot today. So, I figured I'd jump on it, since I have aspirations of running Dusy this year. Anyone? Dusy?
So, it took this old man about 2 hours to get the jeep jacked, and pull the differential. Felt pretty good for me, with a bad back, neck, and arthritis all over.
Then, I spend the afternoon changing the Bronco connector over to a Jeep connector on the new (Bronco) coil actuator. The short version is that Jeep and Dana won't sell the differential parts for the JL Rubicon, so I'm using parts from the new Bronco that fit but use different electrical connectors and don't have the sensor at all. So, I'll use a Z-Automotive sensor fooler/jumper. Checked the assembled connector with a meter. It has the correct resistance for the coil.
Now, I have to pull the passenger side bearing from the diff, then replace the burned out coil, and actuator plate with the Bronco parts, new bearing and reassemble. Simple. Right?
Added for parts. This might be worthy of a pinned thread. So, to make this thread valuable to future owners of JLs with locker failures, I'll post the parts required.
Edit 12/6/24 Added Solenoid Spacer and Plate
BTW, the OEM JL actuator coil plugged into the sensor, which then plugged into the passthrough bulkhead connector on the housing. With this modification, you plug the actuator coil directly to the passthrough bulkhead connector.
- Bronco Raptor Locker actuator coil Dana Spicer P/N 10102021 sourced from any Dana Spicer dealer
- Differential Solenoid Spacer, Dana Spicer P/N 10038787
- Differential Solenoid Plate, Dana Spicer P/N 10143206
- JL style connector TE Connectivity/AMP brand P/N 1-2309436-1 sourced from OnlineComponents.com (min qty 25)
- TE Connectivity pin/socket P/N 1670146-2 DigiKey is the wholesaler, but had to buy from ebay due to min quantity (still had to buy 100 pcs)
- Mouser connector wire seal P/N 571-2138898-1 sourced from Mouser Electronics (min qty 100)
- Z-Automotive Z-Locker-OEM Z Locker OEM – Z Automotive
