roaniecowpony
I think I'm looking for a new coil/solenoid actuator for my front axle locker.
After getting it back from a shop that re-geared it, the front locker never worked. But I had not used the front locker since last summer. Yes, the sensor was full of oil. So I bought the Z Automotive sensor jumper and installed it, which did nothing. So, while the sensor may or may not have been bad, the Z Auto jumper should have worked, and that meant to me that something else was a problem.
In my diagnosing of my front locker, I've found that I have power to the pass-through bulkhead connector into the differential cavity, using the Z Automotive sensor jumper or without. I removed the internal harness from the pass-through connector and rotated the coil to gain a better look. I've cleaned the connectors with contact cleaner and compressed air several times and reconnected them in the open where I could see everything. There is power/ground right up to the connector wired on the coil/solenoid actuator. I wiggled wires and nothing. I checked with a steel tool to see if the coil is magnetized. Nothing.
In searching for a new coil/solenoid actuator, I've come up bupkis. Any help would be appreciated.
