Midwestjeepguy
Midwest
2018 Jeep Wrangler JLUR
Despite having felt pads taped to the windshield bolt heads, a rattle returned from my sun visor area (2018 JLUR). After a quick look it was clear the culprit was the mirror cover vibrating against the plastic windshield molding above it. I then noticed the rubber bump stops on the molding, that are designed to stop the visor from vibrating against it, seemed awfully short. So an Amazon search yielded fuel filler door bump stops that looked like they could snap in place of the factory bump stops. Sure enough, super easy swap! Just pull the old ones out and push the new ones in, only takes seconds and no drilling. $6 for a set of 8 (wanted extras in case I damaged any). Some model years have 2 rubber stops per visor and some have 3 per visor, make sure to check before you order. You can buy them here https://a.co/d/ivFHCiO.
Now the sun visor has enough of a gap not to vibrate against anything. I was able to get rid of the felt pads and the short factory rubber bump stops. See pics below of before/after and the new rubber stops I purchased (in case the link above expires):
Jeep Wrangler JL FIXED - Sun Visor Rattle/Vibration Noise (Solution) 1710866738082-ks
Jeep Wrangler JL FIXED - Sun Visor Rattle/Vibration Noise (Solution) 1710866887595-yo
Jeep Wrangler JL FIXED - Sun Visor Rattle/Vibration Noise (Solution) 1710867031726-oz
Jeep Wrangler JL FIXED - Sun Visor Rattle/Vibration Noise (Solution) 1710867142125-mu
Jeep Wrangler JL FIXED - Sun Visor Rattle/Vibration Noise (Solution) 1710867185767-dh
Jeep Wrangler JL FIXED - Sun Visor Rattle/Vibration Noise (Solution) 1710867375335-k6
Jeep Wrangler JL FIXED - Sun Visor Rattle/Vibration Noise (Solution) 1710867391282-82
Jeep Wrangler JL FIXED - Sun Visor Rattle/Vibration Noise (Solution) 1710867308830-zq
The Fixer
North Jersey
2018 Mojito! JLS, 2018 Firecracker JLUSS
Teacher
Wow, this is a great tip! My passenger side visor rattles all the time. Gonna get the 8 pack as well since we have 3 JLs in the house.
CopperMtnGuy
Ross
Wisconsin
2018 JL Wrangler, 2005 KJ
That's an awesome tip. I'm going to have to check mine now and see if that is what my rattle is.
PrimeTime4370
2019JLUS
I will have to check in to this. Mine recently developed a squeak/rattle noise on the passenger side. Sounded like it was coming from the upper door area.
Midwestjeepguy
Midwestjeepguy
Midwest
Hopefully this is the solve for all of you! Let me know how it goes.
Tortolabob
Cape Cod, Ma
23 Rubicon JLUR, 25 Grand Cherokee, 26 Ram 1500 Rebel 3.0
Thank you! I have been searing for this noise ever since I Brought my 23 Rubi home. Thanks again
PrimeTime4370
2019JLUS
Well, unfortunately, this was not my issue. Tried folding the visor down and still had noise. I think it may be the freedom panel moving around.
Overkill
Michael
Paris, IL
Rubicon392.com
2024 392;2002 TJ Sport;2005 GMC 2500HD;1969 Camaro (x2);1974 Chevy Cheyenne K20
Information Technology
Check the 4 bolts that hold the windshield also. There have been some on the forum that had theirs be loose.
PrimeTime4370
2019JLUS
Yeah, one on the drivers side was loose. Rattled like crazy. this more of a squeak sound. Rubber sounding. If that makes sense.
The Fixer
North Jersey
Teacher
Fixed my vibration! OP, you are my new hero.
Same here! I meant to post on this thread again, I got these bumpers early this week and popped them in. What an improvement!
pfletcher229648
Patrick
Orlando
2022 JLUR XR w/SOT, 2024 JLUR X w/SOT(On Order)
CIO
Now the sun visor has enough of a gap not to vibrate against anything. I was able to get rid of the felt pads and the short factory rubber bump stops. See pics below of before/after and the new rubber stops I purchased:
Always appreciate info that helps settle down the rattles.
Looking at your pictures it seems you haven't installed the visor bracket clips. I highly recommend them to prevent experiencing visor dangle.
Midwestjeepguy
Midwestjeepguy
Midwest
They’re there. Bought ones with a great design, all metal and mount flush. It’s hard to notice them.
https://a.co/d/5SVIY7T
Jeep Wrangler JL FIXED - Sun Visor Rattle/Vibration Noise (Solution) IMG_7072
Midwestjeepguy
Midwestjeepguy
Midwest
Oh man, no better feeling than finally getting rid of an annoying rattle!! Glad it worked!
