Wrangler plug in in winter?
JustinJ
Justin
Saskatoon
2024 Wrangler Sport 2D
Hi folks I live in Canada. Winter here can be extremely cold and I am assuming there is no way to have a Wrangler plugged in? I guess a heated garage is only way to go… any other suggestions?
BXFXJeep
Toronto, ON
2021 4xe Sahara
I live in downtown Toronto, have no heated garage, or home charger, I use public chargers, I drive mostly electric all year including winter, if I had a 120v outlet at home, I would be able to do more electric, if the weather is crappy I just run the gas engine.
Under 0C expect the range to drop, and drop significantly if using the heater or defroster, usually if I have to use the heater I take the opportunity to run the gas engine, but I'm always charging.
My 4xe sleeps in an underground garage.
It all boils down to what are you expecting.
The 4xe is not a BEV, you should expect to run the gas engine regularly just for the sake of maintaining it.
Is there any thing specific you would like to know?
This is my March usage, November 2024 would be 3 years since I bought the 4xe.
Jeep Wrangler JL Wrangler plug in in winter? 1000016815
jludave
The Isle of Long
IT Manager
Aonar
N.W. Iowa
2012 Rubi and Snazzy 2021 JLURD
Heimkehr
Pennsylvania
2021 JLU 2.0T
The factory engine block heater option has indeed been absent for at least two model years now. Aftermarket options are available for your consideration.
Sparty
SW Michigan
04 TJ, 21 JTR, 21 JLR
I wouldn't worry about it - you're in Toronto. Soon enough, someone will take your wrangler so you don't have to deal with it.
JustinJ
JustinJ
Justin
Saskatoon
Hahahahahaha
