winter gasoline = increased fuel consumption
karynm8621
Karyn
NH
2018 Wrangler JLU Sahara
I’ve never heard of “winter gas” before.
can someone please explain this concept? why is this a thing?
Winter-blend fuel has a higher RVP because the fuel must be able to evaporate at low temperatures for the engine to operate properly, especially when the engine is cold. ... A lower RVP also helps prevent drivability problems such as vapor lock on hot days, especially in older vehicles.
geem03
Gary
New Brunswick Canada
2019 Jeep Wrangler Sport
RN/ Firefighter
Worse gas mileage in the winter... even with my dodge ram.... but I do notice better gas mileage when the weather gets milder and then drops with the temperature.... oh well....
wibornz
Ted
lansing, Mi.
www.instagram.com
JL Unlimited Rubicon
Also your rolling resistance is higher. Heck the differential fluid is like honey, all the grease in drivetrain bearing are thick. And then the gas is a winter blend.
roaniecowpony
Retired Engineer
When it gets cold, air up those tires. When it gets hot, air down.
ASMSAS
Marlene
NorCal
Aviation
Yea here in Cali we have a winter blend and we don’t even have a stinkin winter. :asshat:
dsgrey
Kevin
2019 JLU
EPA regs are odd. We have low RVP gas during the summer which is refined to have a lower evaporation rate and lower volatility than conventional gas. I'm not sure if winter or summer blends really make a difference to us anymore. I seem to average around 20mpg anytime of the year with mixed driving.
Wabujitsu
Sarasota, FL
2021 JLUR, 2020 JLU Sahara
Retired US Army
We are “blessed” with winter gas down in FL too. The problem is, the temperature in a 24-hour period can drop from 85 down to 35 - 50 degrees difference - then back up to 85 in two to four days. I’ve noticed maybe a 1-2 MPG less difference.
blnewt
New Mexico
Just ask @cosine he knows!
thanks for the link.
does anyone know when this switch takes place?
curious if my mpg is going to go down soon.
Here in New Mexico it's around the start of November through the end of March. Our JL mpg goes down about 10% in winter unless I find a station on our road trips that sells Ethanol-free gas.
amnesiac
Cleveland
2020 Wrangler Sport S
I got my Jeep at the end of October. Mpg were around 20, it’s steadily dipped since then and is now at 19. hoping it goes up in a month or so.
blnewt
New Mexico
Maybe you're getting an extra mpg of fun now :)
viper88
Nick
IL
BINGO! You hit it on the head. Lower MPG in winter is due to a combination of things. Everything you said plus longer warm up times. Plus the use of remote starters and idling to warm up.
