winter gasoline = increased fuel consumption
NewJLU2019
Curtis
2021 Rubicon Unlimited 2019 Sahara Unlimited
Every spring gas prices seem to skyrocket to the highest prices of the year. Why does this happen? In explanation, we hear the experts say that many of the refineries are “down for maintenance while transitioning from winter-blend to summer-blend gasoline,” but what does this mean?
The difference between summer- and winter-blend gasoline involves the Reid Vapor Pressure (RVP) of the fuel. RVP is a measure of how easily the fuel evaporates at a given temperature. The more volatile a gasoline (higher RVP), the easier it evaporates.
Winter-blend fuel has a higher RVP because the fuel must be able to evaporate at low temperatures for the engine to operate properly, especially when the engine is cold. If the RVP is too low on a frigid day, the vehicle will be hard to start and once started, will run rough.
Summer-blend gasoline has a lower RVP to prevent excessive evaporation when outside temperatures rise. Reducing the volatility of summer gas decreases emissions that can contribute to unhealthy ozone and smog levels. A lower RVP also helps prevent drivability problems such as vapor lock on hot days, especially in older vehicles.
The US Environmental Protection Agency (EPA) says conventional summer-blend gasoline contains 1.7 percent more energy than winter-blend gas, which is one reason why gas mileage is slightly better in the summer. However, the summer-blend is also more expensive to produce, and that cost is passed on to the motorist.
The switch between the two fuels happens twice a year, once in the fall (to winter-blend) and again in the spring (to summer-blend). The changeover requires significant work at refineries, so oil companies schedule their maintenance for those times when they will already be “down” for the blend switches.
As a consumer, the main thing to understand is that there are real reasons for the switch from winter- to summer-blend fuel, even if it results in some pain at the pump.
geem03
Gary
New Brunswick Canada
2019 Jeep Wrangler Sport
RN/ Firefighter
Here in New Mexico it's around the start of November through the end of March. Our JL mpg goes down about 10% in winter unless I find a station on our road trips that sells Ethanol-free gas.
So does ethanol free gas give better gas mileage?
viper88
Nick
IL
I live in IL, right in the the corn-belt, so almost all of our gas has ethanol. Years ago I did find ethanol-free gas and tried it for several tanks. It was not a scientifically controlled study or test but I think got better MPG with ethanol-free gas. It also cost more so any improved MPG was probably offset by the additional cost.
https://www.roadandtrack.com/car-culture/a17240/how-does-ethanol-impact-fuel-efficiency/
https://www.cars.com/articles/anoth...may-vary-for-the-worse-ethanol-1420663037150/
geem03
Gary
RN/ Firefighter
Out here in the east coast of Canada, we can get ethanol free gas but it comes at a higher price... like you said...I am assuming the cost offsets the mileage gains....
blnewt
New Mexico
Just ask @cosine he knows!
The corn mix in ethanol is similar to a filler, if you have 10% ethanol you can expect close to 10% less mpg vs ethanol-free fuel. Not sure, but the flex fuel vehicles that can accept E85 should burn Ethanol more efficiently AFAIK.
Used to run Ethanol-free fuel w/ our Infiniti G quite often, and the increase in mpg was almost exactly 10%. Haven't found Ethanol too often w/ our JL to get as large a sample size, but it did go up a couple mpg in those few times I've used it.
And yeah, if the cost of Ethanol-free fuel is greater than 10% the savings is a wash, but for those of us 2dr JL owners w/ dinky 17 gal tanks we need all the extra mpgs we can get :(
geem03
Gary
RN/ Firefighter
Tell me about it! I feel I'm always at the pump!!!
viper88
Nick
IL
Truth!
geem03
Gary
RN/ Firefighter
I've got a question!?!
Could one replace the jl fuel tank with a jlu fuel tank?
Would there be enough room?
viper88
Nick
IL
Nope. Your best bet for a little more range in the wilderness is probably external gas cans.
