Winch install question
Firemadz
York, PA
2018 Wrangler JLU Rubicon, 2018 JLU Sahara
Battalion Chief
Just purchased a Quadratec Stealth winch, hoping to install this weekend. Can anyone provide pics of how you routed the winch cables from the bumper to the battery? I’m particularly interested in seeing pictures from underneath. TIA!
cOtter
Southern, Indiana
‘20 Sahara 2.0L Ocean Blue Metallic, Toyota Highlander & Pontiac G6 coupe
Senior Manager PM (Automotive OEM)
If you have not yet checked.... I would recommend google / YouTube. It’s unbelievable all the technical instructions that can be found on there.
Roky
Roky
This is how I did it, and so far so good :fingerscrossed:. I just made sure that the cables don’t rub against any metal. I took some hydraulic hose and split it down the side to wrap around cables where they are most vulnerable.
When I tied them off to the frame, I zip tied the cables together then zip tied the zip tie to the frame. Pictures are kinda in sequence top to bottom, if you have any questions, happy to help ...:)
Jeep Wrangler JL Winch install question 12EF74ED-8A4B-4AE8-9D73-EB65E3F3D424
Jeep Wrangler JL Winch install question 29B3EAC7-80AE-4BB4-A95C-AC89FA210550
Jeep Wrangler JL Winch install question 1423CC04-41B8-4C03-8491-813AAE74E0DE
Jeep Wrangler JL Winch install question A3D3CF32-0956-45A6-B3AD-2875800E8085
Jeep Wrangler JL Winch install question 597DFFF1-DEEE-41BF-B5C0-5B7F204571F6
Firemadz
Firemadz
York, PA
Battalion Chief
Thanks! Hopefully will get to the project Saturday. Also helping my sister with her rear bumper install, so hopefully we have time to fit it all in.
shekmark
Manasquan, NJ
Yes
There is a you tube video by Trail Recon. Installing a OEM steel bumper and a Smittybuilt winch but he shows how he routes the cables along side the right headlight using a hanger to pull the wires.
Bryce
Bryce
Acworth, GA
2019 JLUR
I watched that and installed my Smittybilt X2O Comp winch the same way. Worked great.
mikej
SF Bay, California
2018 JLUR, 2023 Rivian R1T
Seconded. This was the video I followed for routing my cables.
FitBliss
Gabriel
MN
2019 Jeep Wrangler Limited Rubicon
Probably a silly question but do you have an aftermarket bumper or winch carrier to mount the winch to?
smokinjeep
jim
MN
2019 JL on order
What is this youtube you speak of? :)
Chemy350
Atlanta GA
Mortgage Loan Officer
I took the airbox out and it made running the wires very simple.
Biohazard
Nathan
Bristol, TN
2018 JLUR (sold May 2020); now own 2020 trd pro Tacoma
We were all new at some point, not silly at all.
If you have the stock steel bumper, you need a winch mount that fits behind it. If you have the plastic bumper, then you'll need a new bumper.
FitBliss
Gabriel
MN
hehe I know, I have a winch I was making sure you did ;)
Dagwood
Alabama
2019 Jeep JL, 1999 Jeep xj, 2008 Scion XB, 2015 Scion XB, 1966 Ford F100, 1969 Oldsmobile
Well done with the cable tie to cable tie, that will greatly reduce chance of chaffing the wire. Aircraft standard.
TheMachine
Arizona
Ford F-150
Apologies up front if this is not where I should be posting this but I'm installing a new warn and replacing the the cable with synthetic. The Hawse fairlead I'm looking for is in this picture. Does anyone know the brand or where I can purchase it?
Thanks!
Jeep Wrangler JL Winch install question maltese fairlead
