Why the hate on Dynatrak ProFloat60?
FreedomFur
Elliot
Concord, NH
2021 JLU Willys
I had the misfortune of hitting a pot hole on a trail and bending a brand new 2022 Rubicon Dana 44 with KO2 37” tires on it (2 months into ownership). I am using the insurance money to put on a Dynatrak ProRock 44 and have been looking for a quality 5 bolt axle in the rear for a future project since I am now super skeptical of the Dana 44 strength.
Dynatrak’s ProFloat XD60 gets a ton of hate on [Banned Site]. But for someone like me who doesn’t plan to anything larger than a 37” or 38” tire, this seems like a great option. The only other thing out there I could find in a 5 bolt pattern was the Currie axle. I would much prefer a full float, but don’t really want to go to an 8 lug right now. The ProFloat is rated to 40“ tires.
This isn’t a “now” project. The cost of axles is RIDICULOUS. At the end of 2019 you could buy a Dana UD60 for just over $5k and now they are almost $10k!
FreedomFur
FreedomFur
Elliot
Concord, NH
2021 JLU Willys
No thoughts from the forum?
FreedomFur
FreedomFur
Elliot
Concord, NH
2021 JLU Willys
Maybe ask over there why they don't like it. ?‍♂
Not a member on their forum. They are not a fan of the semi-float design especially on 40s. Wondering if anyone here has direct experience now that this has been out for a few years.
mnjeeper
MN
98 TJ, 2021 JLUR
Full float is far easier to trail fix...so that's likely the reason.
What's the cost difference?
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
Generally speaking, full-float is stronger than semi-float, all else being equal.
Some groups of people get overly focused on those kinds of details.
FreedomFur
FreedomFur
Elliot
Concord, NH
2021 JLU Willys
If I went full float I would have to get Dynatrak to build it with a 5 vs 8 lug. I would be its about $10K. Haven’t seen a price yet on their ProFloat, but Currie’s similar model is $6K.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
A full float 5 lug will still require a wheel change because the hub is big and it sticks out through the center of the wheel. Also, it's likely to have at least a 5x5½" bolt pattern where the JL has a 5x5" pattern. There's no huge benefit to running a 5 lug pattern
FreedomFur
FreedomFur
Elliot
Concord, NH
2021 JLU Willys
Ugh. Makes me wonder if I just run as is, and then in a few years make the full switch to Dana 60 8 lug, front and year, and sell off the ProRock44 and rear Dana 44 at that time (versus keeping the ProRock 44).
Jmos4
2020 Challenger Scat Pack M6/2007 Ram 2500 G56
Hi,
Full float if you break a axle the wheels are still attached, a semi-float like our current 44's if a axle breaks it can slide out or if it breaks at the flange will no longer be attached and a pain to drag off a trail.
Regards,
OBJLU
Henry
Los Angeles
2018 JLU Rubicon
I know someone who has been running the pro-float for the JL for over 2 years. all on 40's and running King of Hammer trails, zero issues. I'm running a semi-float 60 from fusion, working fine so far, the 40 spline axle shafts made me confident about running it.
  • Like
Reactions: J0E
OBJLU
Henry
Los Angeles
2018 JLU Rubicon
Hi,
Regards,
Thats on the earlier TJ, etc, it's all bolted into the axle so now they're not going to slide out. Breaking at the flange could happen but not likely, what will happen is it will bend.
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
Is Dynatrac a sponsor over there? Back in the days of JK Forum, that was usually the deciding factor as to whether or not something was panned or praised.
Digger 5
Pacific NW
JK
The ProFloat really minimizes the issue had with both JK and JL/JT rear axles- bent wheel hubs. The JK/JL/JT all have a wheel bearing that is significantly further inboard than the previous TJ Jeeps. I can't really remember seeing a TJ with a bent axle flange. The deeper wheel bearing allows more leverage on the flange and is the reason (along with weight) so many JK/JL/JT failures are seen.
The Dynatrac ProFloat axle addresses these issues.
No question, a full float design is superior to a semi-float design, but, it's not always needed. A bloated JL/JT on 40's should have a full float but if you stay under 6K# this should be a great option.
