Wheel Spacers or No
To space or not to space
  • Total voters
Brock9281
Robbie
Alpharetta GA
2021 Rubicon Unlimited
Currently running 35s with Method 703 wheels in 0mm offset. Debating on if I should add spacer or not? Is it possible to find a 0.5” spacer? Anything needed to add to existing wheel?
Jeep Wrangler JL Wheel Spacers or No DB38C946-46C7-44E7-A0E0-F326DFCC3A70
Jeep Wrangler JL Wheel Spacers or No A683D685-6206-4B8C-914E-5FD42BA1FAFB
Jeep Wrangler JL Wheel Spacers or No E3F58BC6-42AB-4E58-9616-F3CB8417C519
  • Like
Reactions: J0E
JSFoster75
Bluff City, TN
Personally I like the wider stance with the spacers... You will probably have an easier time finding a 1" spacer, but you will likely have to cut the studs since they are considerably longer and would hinder the rim from mounting snug to the spacer.
  • Like
Reactions: J0E
Steph1
Steph
Quebec, Canada
Jeep JLU , Audi Q5
True and false. Only the ugraded wheels on your avatar won't accept a 1 inch spacer (1.25'' minimum) because the back pockets are not as deep as other mopar wheels. the regular Rubi wheels and the 4Xe wheels accept 1 inch spacer no problem, as the inner pockets are deep enough to accept the protruding lugs.
Some Random Guy
Washington
Comptroller
Strictly stance/look
Ok, based on that I vote yes. But I have no experience using them (I’m hard on my rig offroad). It sounds like you should contact the wheel vendor and see if they can advise you on compatible spacers/shims. If you move out to 1” I’d change my vote.
jaymz
Jay
Inland Empire
2018 Rubicon Unlimited
All of the 1/2" spacers I've seen are simply shims that sandwich between the wheel and the rotor. You'll likely need longer wheel studs to ensure proper thread engagement with the lug nuts. Not worth it in my opinion.
Steph1
Steph
Quebec, Canada
Jeep JLU , Audi Q5
Nope, ran them on my JK and before my Black Rhino wheels on my JL.
Jeep Wrangler JL Wheel Spacers or No 41814C10-2CC0-4CEB-BED5-25E06D03E652
Zandcwhite
Zach
Patterson, ca
2019 jlur
A half inch spacer is just a shim, but our wheel studs are plenty long enough to run them. We've been running 1.5" spacers with factory wheels and 37-38's for nearly 50k miles but the internet likes to tell me it's unsafe, won't hold up on the trails, and my wheels are going to fall off. I guess it's a good thing my jeep can't read to know all that? She gets around and hasn't had a problem on any trail we've run.
Jeep Wrangler JL Wheel Spacers or No 20220530_142846
Jeep Wrangler JL Wheel Spacers or No 20220221_113205
Jeep Wrangler JL Wheel Spacers or No 20220220_140417
hoch
Hoch
UT
2018 JLUR 6-sp
Apologies for bumping an old topic but I have to make sure we’re all on the same page.
Just to clarify, the wheel spacers you’re using are ones where the spacer is bolted to the hub, then the wheel is bolted to the spacer.
That is a proper spacer.
I think what the other poster meant by shim are one that simply slides in, like below. I would not recommend these.
Jeep Wrangler JL Wheel Spacers or No 1675183950475
