I don't know of any reputable brand with 2 inch wheel spacers. Spidertrax has 1.75 and Synergy has 1 5/8. I would stick with one of those brands.Running a stock JLU Rubicon. Down the road am looking to lift it 2.5 or 3.5" and put on 35's. Should I wait to add 2" wheel spacers until I lift it or can I do it now? (had an 07' but never did any mods to it...so I am new to all this)
Thanks. Rough Country has 2" ones... but have heard bad things about Rough Country. A few people have told me not to put on wheel spacers that they mess up the suspension. Thoughts?I don't know of any reputable brand with 2 inch wheel spacers. Spidertrax has 1.75 and Synergy has 1 5/8. I would stick with one of those brands.
You can put them on at anytime.
Personally for wheel spacers I would stick with Spidertrax or Synergy. They are top tier.Thanks. Rough Country has 2" ones... but have heard bad things about Rough Country. A few people have told me not to put on wheel spacers that they mess up the suspension. Thoughts?
It seems that many of the wide spacers for Jeep applications include Loctite w/ the spacers. We've run spacers on our cars (NOT 4x4s) w/ spacers that didn't include loctite, just torqued spacers to spec, check torque again after 100 miles, than every tire rotation @7k miles. Spacers in my applications always held torque after that initial re-torque @ 100 miles w/ NO Loctite. I assume since these Jeep applications would see 4x4 duty w/ more severe tire abuse that Loctite is something that needs to be added to keep torque secure but ???.@AmesosaurusRex .. and all of yous… I've been debating spacers for about a month now & I asked myself the same question. I have stock wheels/tires and no desire to change, so I was going for the look. Then I did some reading up on spacers & I was thisclose to starting a thread on this topic.
I understand the benefits of grip, handling, traction, etc., but then I had some concerns about affecting the suspension and possibly jacking with the warranty terms. I'm cautious about effing with things that make the wheels go 'round, and a lotta the research I did mentioned how the wheels are designed to be where they are (which makes sense). Of course, larger tires need proper clearance, but it seems far from worth it if the goal is purely aesthetic.
Then there's the maintenance. I torque my wheels to spec (since the dealer doesn't seem to) so I'd be anal enough to take the time to do the same periodically if I ever decided to add spacers. I still check the torque every so often. I'm curious as to how many owners who have spacers, only for the look, actually keep up with the maintenance after X-amount of miles and, do you have any concerns?
Sorry if I've hijacked, @clb616 …
I was nervous about putting the spacer on, but so far so good. I installed synergy spacers because my 315/70/17 tires were rubbing on the lower control arms at full turn. ( I have a sport with shorter axles) I painted them black around the edge with high temp automotive paint so they match the rim and don't stand out before installation.
I have used Spidertrax and Synergy spacers on multiple jeeps with 38-40 inch tires. The loctite was used and lugs were torqued to spec.It seems that many of the wide spacers for Jeep applications include Loctite w/ the spacers. We've run spacers on our cars (NOT 4x4s) w/ spacers that didn't include loctite, just torqued spacers to spec, check torque again after 100 miles, than every tire rotation @7k miles. Spacers in my applications always held torque after that initial re-torque @ 100 miles w/ NO Loctite. I assume since these Jeep applications would see 4x4 duty w/ more severe tire abuse that Loctite is something that needs to be added to keep torque secure but ???.
Would be interested to hear anyone that's had Jeep spacers that included Loctite, if they've ever lost torque on their lug nuts over time??
Part of the reason I asked the question about the need for the spacers in the first place is that they have a Rubicon, and as far as I have read, you should not need spacers to do a 35" tire on a Rubicon, the wider axles give plenty of clearance. In fact, even 37" tires seem to have plenty of clearance with a basic lift.@AmesosaurusRex .. and all of yous… I've been debating spacers for about a month now & I asked myself the same question. I have stock wheels/tires and no desire to change, so I was going for the look. Then I did some reading up on spacers & I was thisclose to starting a thread on this topic.
