what is the physics of using snatch ring/block?
ahmadtaha1988
ahmad
dubai
2023 JL 4 door Sahara
I been reading about snatch rings and how they can reduce the load on the winch.
So under no friction it exerts half the load but pulls at half the speed. Effectively some form of gearing... I studied pullies in physics once upon a time.. can someone refresh me on what is going on here and how this happens!
Thanks
Reinen
Utah
2021 Jeep Wrangler JL Rubicon
You got the jist of it.
When you have a line going from your winch, to a snatch block on the load and back to your Jeep both lines are pulling the load. Not exactly evenly because of friction but close enough. So that results in a mechanical advantage, where your winch is only pulling half the load (or close enough to half), but has to pull twice as far to move the load the same distance.
ahmadtaha1988
ahmad
dubai
Thanks, I understood how I can use it to recover myself using a tree or another stationary car. How about if I am helping someone else who is stuck and does not have a winch? Is there use for a snatch ring? How does the set up in that scenario go .?
JDub11
Illinois
2020 jl 2012jk
Not only do you get the mechanical advantage, your also pulling closer to the drum with that much line out so you have more power at the winch also.
dcmdon
Boston and Northern NH
2022 Gladiator Mojave
Thanks
You've got it exactly right.
txj2go
DFW
The normal process would be to hook your winch to a tree to recover yourself, or hook your winch to another vehicle to recover it. IF your winch doesn't have enough pull for one of these operations then a snatch block will help. You can connect the snatch block to the tree and run the winch line through the block and back to your Jeep. This gives you twice the pull against your Jeep but pulls half as fast. If you are recovering another vehicle you connect the snatch block to the other vehicle, run your winch line through it and back to your Jeep or to another tree.
Valpo Jeep
Doug
Valparaiso IN
15 Mas Ghibli, 18 JLU, 05 Gulfstream RV
A snatch block to help with recovering someone else would help if you can’t get a straight pull. It won’t increase your recovery power but it would help at awkward angles assuming you could anchor the block to something.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
It won't increase your recovery power?
txj2go
DFW
The thing that the snatch block is attached to will see up to twice the force as your winch is putting out, depending on the angles of the 2 ropes.
Ratbert
PNW
Software Engineer
Exactly. That's why I questioned what @Valpo Jeep said.
Valpo Jeep
Doug
Valparaiso IN
If you are using the pulley to simply change the direction of force then there is no mechanical advantage.
Jeep Wrangler JL what is the physics of using snatch ring/block? 1678712355184
No mechanical advantage if used like this
