What does a + 30 offset look like
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Yes. I run a tall-ish Cooper STT Pro tire and when loaded with mud they will rub when stuffed but a dry tire, no issues.
Great, thanks.
Turbomark
St Louis
2021 Wrangler Sport Altitude
18x9 +18 offset with 275/70/18. Pokes just enough to look “tough” but not enough to sling crap all over the Jeep. Last photo is with 1” spacer lift.
Jeep Wrangler JL What does a + 30 offset look like 64B486E6-E42E-40FD-8056-43EF400DF1F9
Jeep Wrangler JL What does a + 30 offset look like FD19E897-F44C-4B2A-A2A1-0E6889E1F91C
Jeep Wrangler JL What does a + 30 offset look like 1959A674-5407-41E1-A521-19EF2472D3FE
Jamrock
Jamaica
Suzuki
I currently have the Black Rhino Warlord in a -12 offset, didn't realize they would stick out as far as they do, the only other option for this rim is the +30, I absolutely love the Black Rhino Rims in the gunmetal as it perfect for the color of my Jeep. I live in NS Canada, so roads are crappy and backroad even crappier...lol, and we also have ugly winters, too much spitting up side of Jeep from the offset sticking out so far, although the -12 if aggressive and looks good, its not what I wanted
I have only seen -12 on Sport and Sahara models. The Rubicon axles are wider so -12 would stick out quite a bit on yours.
On the other hand, +30 sounds a bit high. Have you tried looking for another wheel in the color that you like?
Please post a picture of your Jeep so we can see what it looks like now.
Steph1
Steph
Quebec, Canada
Jeep JLU , Audi Q5
You are dead wrong, it would stick out no more than it does on the Rubicon. True that the Rubicon have wider axles than Non-rubicons, but Rubicon fenders are also wider than non-Rubicons buy the same amount.
Jamrock
Jamaica
Suzuki
I suspect that we are talking about different things.
I am speaking about the difference between the outer edge of the wheel and the Jeep's body. If I am understanding you correctly, you are speaking about the difference between the outer edge of the wheel and the Jeep's fender.
Wheels with -12 offset are a good way to give a Sport or Sahara a wider, more aggressive stance.
Take a look at Snoopy
https://www.jlwranglerforums.com/forum/threads/post-pics-of-your-sport-with-35-tires.17494/page-4
I was hoping that the OP would have posted some pictures so I could see what they look like on a Rubicon. I would expect them to stick out more with the wider axles.
Steph1
Steph
Quebec, Canada
Jeep JLU , Audi Q5
Well, if the Rubicon and non-Rubicon are fender less, then you are right saying that they would stick out more on the Rubicon since their axles are 1.5 “ wider or 3/4” per side. But if both vehicles have their fender on, they would stick out of the fenders equally since the Rubicon have wider fenders to compensate for their wider axles.
NewJLU2019
Curtis
2021 Rubicon Unlimited 2019 Sahara Unlimited
35" tires and Vapor Fuel Wheels and -18
Jeep Wrangler JL What does a + 30 offset look like Naked
NewJLU2019
Curtis
Jamrock
Jamaica
Suzuki
Thanks.
I guess the mud flaps will be necessary since they extend past the fenders.
NewJLU2019
Curtis
