Gaylon
Gaylon
Auburn, CA
1987 Toyota Land Cruiser
I'm finally getting around to a build thread about a year into my wife's ownership of her first Jeep. She chose to name her Jeep "Warthog" after the vehicle in "Red vs Blue" or RVB. If you are not familiar with the show, here is an exerpt from the episode with the "Warthog". https://rvb.fandom.com/wiki/Red_Gets_a_Delivery
She purchased her Jeep from Ourisman in MD for 8% under invoice in March of 2019. Sting Gray JLUR with 3.6, 850RE, Packages 24R, ERC, DFT. Factory options were keyless entry, steel bumper group, safety group, LED, 8.4 radio, trailer tow, cold weather, body color flares and hard top. This was her first Jeep and her only requirement was she wanted AEV Savegre wheels with 35" tires.
Current Modifications
Wheels/Tires
AEV Savegre II 17x8.5 +25 Offset Wheels, Nitto Ridge Grappler 37x12.5R17 124D
Suspension
Mopar 2" (Replaced AEV 2" spacer lift 12/1/2020)
Daystar Coil Isolators for Mopar Lift
Synergy Front Track Bar
Synergy Rear Track Bar
Synergy Lower Control Arms
Exterior
Rock Hard Patriot Sliders Flat with Plate Delete
Warn Zeon Platinum 10-S Winch
Mopar Winch Mount Kit
Factor 55 Fairlead Hawse
Factor 55 Flatlink E
Maximus 3 JL Stealth Front License Plate Bracket
Maximus 3 JL Filler Trim Plates Zeon Winch
Alien Sunshade
Mopar JL Oversize Tire Carrier
Mopar Tailgate Reinforcement
Trasharoo
Bestop Sunrider Soft Top
Antenna X 13in Antenna
Carolina Metal Master Mirrors
Interior
Formula One 15% Tint
69 Designs Phone Holder
XG Cargo Gama Storage Bags
Bestop Underseat Storage Organizer
MORE Dead Pedal
My Medic Advanced First Aid Kit
Maximus-3 Rear Flashlight Mount
Element 100 Fire Extinguishers
10LB Power Tank OBA
Bartact Seat Covers
Electronics
Tazer Min (Replaced AEV Procal Snap 12/1/20)
Uniden CMX760
Quadratec CB Antenna Mount
Mods purchased waiting to be installed
LUX Rock Lights
ARB Twin Compressor
Recovery Gear
Why did you decide to change from the spacer lift to the mopar lift?
Brian0128
Brian0128
Annapolis, MD
2019 JLUR, 2018 Toyota TRD PRO
Engineer
we wanted a little more than the 2” lift that the AEV provided and came across a great deal on the lift.
Gaylon
Gaylon
Auburn, CA
So, no complaints about the AEV, correct? I am planning going that route and am looking for feedback on it. Only running 315's on a rubicon.
Brian0128
Brian0128
Annapolis, MD
Engineer
AEV was great with the longer Mopar control arms!
HammeredGold
Maryland
Wrangler Willy's Sport
Great build. I just ordered my first jeep so I'm going to steal all your trail locations you posted about since we're practically neighbors. I'm in Riva.
Brian0128
Brian0128
Annapolis, MD
Engineer
The Jeep has been working great for what we do so there haven’t been any updates. We are headed out tomorrow to run some blue trails at Rausch Creek in the snow so we decided to install the Rockhard 4x4 LCA skid plates that we have had sitting on the shelf for 2 years as a precaution.
Jeep Wrangler JL Warthog JLUR Rig Journal 38D7B302-E2EC-403C-9FAE-93A537930EFA
Jeep Wrangler JL Warthog JLUR Rig Journal B39B38DB-AD9F-4449-9F91-9A1656E8044C
Jeep Wrangler JL Warthog JLUR Rig Journal 8ADA1549-0975-4E34-B6D3-2570398C03A2
Jeep Wrangler JL Warthog JLUR Rig Journal 0C5BFA33-A651-4FB8-AADC-90C39766E274
Brian0128
Brian0128
Annapolis, MD
Engineer
Did a battery replacement on the JL yesterday. We went with an Odyssey H7 for the main battery and a Duracell Aux14 for the auxiliary battery. Took about an hour and a half. I’m glad I bought extra clips for the fender because I broke 5. I used an E6 socket to remove and reinstall the battery posts on the aux battery.
Jeep Wrangler JL Warthog JLUR Rig Journal 322213392_1559215867915235_929151753817311891_n
Jeep Wrangler JL Warthog JLUR Rig Journal 322551428_682753830115564_2033357603674222939_n
Jeep Wrangler JL Warthog JLUR Rig Journal 322485789_2400164926819197_7656246286080451912_n
Jeep Wrangler JL Warthog JLUR Rig Journal 322199098_684503986552673_8616890564798084257_n
GrayWolf.Overland
Subash
Maple Ridge, BC, Canada
2025 JLU Rubicon (Anvil Gray)
@Brian0128 Super nice build and great stance on 37s. Did you have to adjust the steering stop bolt to eliminate any rub at full-lock on the savegere wheels? esp after you centered axles through adjustable trackbars?
Brian0128
Brian0128
Annapolis, MD
Engineer
The steering stop bolt is not the limiting factor with the steering with this build, it's the Synergy lower control arms. The Savegre offset causes the 37" tires to come in contact with the Synergy LCA's. 4.5 wheel offset would be better but we preferred the tread to be just under the fenders.
GrayWolf.Overland
Subash
The stock control arms inward bend cleared it but the synergy did not eh?
I am doing 5.45 offset wheels on 37 KO2. I will still be on stock LCA after lift as I opted to do geometry correction bracket + track bars. All stock control arms
Chief_Dan
Tennessee
2020 JLUR Stingray
@Brian0128
Since you just responded to this thread, I would like to ask a few questions.
1. How have your lockers held up? Any issues with the sensor or anything?
2. How have the axles held up to the heavy 37s?
3. How have your ball joints & suspension held up?
Just curious as I am finally about to get going on lift, tires, & other mods to my JLUR. Life & other expenses keep getting in my way. But, I only have just over 20,000 miles & not a lot of "hard" offroading.
Thanks! :rock:
Brian0128
Brian0128
Annapolis, MD
Engineer
No issues with the lockers. I change the diff fluid front and rear every 25k miles.
No issues with the axles on the 37's. We go to Rausch Creek and wheel hard blue's and some easy black's 4x a year.
No issues with the OEM ball joints yet. 61k miles. Swapped the shocks, springs and sway bar links at 50k with a set of takeoffs that I picked up locally that had less than 500 miles. The bushings on the sway bar links were worn out the rear shocks were seeping oil.
Chief_Dan
Tennessee
2020 JLUR Stingray
Awesome, that's some solid information. Thank you for taking the time to let us all know.
Such a sweet rig!
:captain:
