KAMIECON JLUR build journal
KAMIECON
KAMIECON
2021 JLUR
some of the lights came in along with the Switch-Pro 9100. Outstanding quality and easy to install. Thanks to Expeditionbuild, I got them wired pretty easily. Baja Designs are very well built.
mikem20
Woodland, Ca
2020 JLUR
Your Jeep is looking great!!!! 👍🏻
KAMIECON
KAMIECON
2021 JLUR
got the tent and awning finally after a long wait. They are mounted on a quick disconnect kit that will allow me to have it on and off relatively fast. The tent and awning will be stored inside the garage unless I need to use it... for now.
ExpeditionBuilds
Rock Sponsor (Level 1)
Steven
Chicago
www.youtube.com
2020 Wrangler Recon
Photographer/ Content Creator
Nice set-up!
-Steven
KAMIECON
KAMIECON
2021 JLUR
Finally! The most important item for wheelin’ is installed. ARB twin air. Mounted underneath the passenger seat. I went with a dual fitting. One under the seat and one external by the front bumper.
KAMIECON
KAMIECON
2021 JLUR
Rugged Ridge DRL chop kit. Little Sunday project. These took 4
Months to arrive and I had some drama but they’re good stuff when it’s all done. It really opened up the wheel well while remaining very stock. Super bright and the turn signal is much bigger and brighter.
mikem20
Woodland, Ca
2020 JLUR
Both of those mods look great!! They’re on my short list to get. Gotta get my lift on first tho.
KAMIECON
KAMIECON
2021 JLUR
adding lights to the rack was a lot more work than anticipated...wires were routed inside the rack rails and then through the roof via the marine grade port. quick disconnect routed at the same location as the factory roof disconnect point for ease of operation. Everything is routed through the rear panel and underneath the truck to the engine bay where the SwitchPro connections were located. This setup allows 360 coverage with short/medium/and long range lighting. Still waiting on the Rock lights to finish up.
Baja Design SP2
Baja Design SP1 (chase)
KAMIECON
KAMIECON
2021 JLUR
This is the setup for the future AAL cargo system coming next year... Let there be power!
KAMIECON
KAMIECON
2021 JLUR
A little ghetto setup for the boards while I’m waiting on the actual brackets, but it works great.
Northridge4x4
