Upgrading from the 5" UConnect3 to 7" UConnect4?
El Zilcho
Max
San Diego
2018 JLU Sport, Rubicon axles
I’m ordering one today so let us know how it goes lol
So far bad news. Got one with part #P7EV04DX9AA. If you connect it without changing programming, all the buttons except everything climate related works. Climate shows as Climate Off on the screen and you cant turn it on. With OBD JScan tried changing to different modes. So in MTC modes climate does not work. With dual or single zone ATC most of the climate buttons start working, but you cant change temperature or blower speed. In last mode SNA ( have no idea what it means) everything works on a screen, but blower does not blow :( So looks like for it this center stack to work, we need new mode, some sort of combination of ATC and MTC
Jeep Wrangler JL Upgrading from the 5" UConnect3 to 7" UConnect4? IMG_2587
CptFloridaMan
Gabriel
Orlando
2018 JLU Sport 2.0
So best bet is to just get one that has the dual buttons but leave it in sync mode? That’s a shame since I have it shipping now. I should’ve waited but was hopeful it would work. What setting is the stock hvac to get it working after trying all that?
Does anyone know the part number of the dual zone hvac stack? Cause if anything we can just set it to that and get it working.
El Zilcho
Max
San Diego
Single zone MTC. I’m still hopeful. Basically everything forks, but not in the same mode. There should be a way to combine everything in the same programming mode.
elf883
steven
NY
2024 jlu willys anvil
stationary engineer
What’s the sun sensor for? My jeeps not wired for the cabin sensor so I’m banking on the hope of using the right setting for that center stack to work.
95% of the jls are wired for the sun and cabin sensor
you dont have the plug behind the panel ?
i had all the wires there :)
BakednShaked
Eric
Ottawa
JLU
Just did the 5” to 7” swap. Smooth as butter… but… none of my HVAC controls work.
Anyone have advice? Do i need the cabin air sensor and Tazer to program it?
Jeep Wrangler JL Upgrading from the 5" UConnect3 to 7" UConnect4? A0604D65-5526-4E9C-98D5-DC8E9DBD4145
Jeep Wrangler JL Upgrading from the 5" UConnect3 to 7" UConnect4? 04C3F64F-C9C5-40B1-BBAA-2E994D8DAA87
Gregj
Greg
West Texas
With that control you will need to change the settings to dual zone ATC, if you don’t have the temp sensor and the sun sensor it won’t work.
Gregj
BakednShaked
Eric
Ottawa
JLU
Gregj
The wifes jeep has the sun sensor up top, but i didnt get the cabin air temp. Ordering that tomorrow.
For the settings to dual zone ATC is that done on Jscan,Tazer, or can I use my laptop and an ODB cord?
scottedontknow
PA
89 YJ, 95 YJ, 2019 JLU x2
You should need to change anything. Set it to singe zone ATC and give it 24 hours
scottedontknow
PA
You need a bypass and JScan or tazer
elf883
steven
NY
stationary engineer
which can be purchased and installed
infotainment.com
u can also use jscan to turn the controls on or if purchsed from infotainment they send you a programmer which does it all for you , easy peasy
jscan u need the app - the security cable -- purchase on amazon - and a jscan vin purchase
open jscan
goto adaptation
then miscallaneous
then hvac configuration
select dual zone atc
save 2 times should work right away
scottedontknow
PA
That’s not a dual zone stack. Set it to single zone and save it in JScan. Leave it go for a few sleep cycles (1 hour- over night)
BakednShaked
Eric
Ottawa
JLU
infotainment.com
open jscan
goto adaptation
then miscallaneous
I bought the radio, bezel and HVAC stack from Mopar.
Seems like ill need to get JSCAN then, I really appreciate the quick and helpful responses!
