UPDATE - check engine blinking on 2024 JL
Leights7
Leighton
Calgary
2018 Jeep Wrangler JL
UPDATE - for those following, I have a brand new 2024 JL 3.6, which had check engine light flashing with a rough idle. Dealer says it’s a malfunctioning O2 censor. Says the malfunction was causing the engine to think it was too rich and instead ran lean which caused the misfire. They said even though it was a misfire no engine damage occurred. The issue now is that the sensor is on back order.
Dale's Jeep
Dale
Michigan
2018 Jeep JL 4door Rubicon
Retired U.S. Army 23 years
Of course it is. What a kick in the nuts. Sorry
alphawolff
california
2021 JLU
Let it sit there for the 30 days then force a buyback. This really isn't your problem unless you special ordered it and it's a hard to find trim.
Doubt it's an direct o2 sensor issue anyway. Possible oil leaking onto the sensor which I figured they would've mentioned.
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
Without looking, I'm pretty sure you can get the sensor on Rockauto. Obviously won't be free like at the dealer, but peace of mind is priceless. I would DIY this one.
Leights7
Leighton
Calgary
It sadly is a factory order which makes it more frustrating. I’m not sure what the buy back options I have as I’m in Canada.
alphawolff
california
2021 JLU
In Canada, there are no definitive lemon laws in place either federally or provincially.
Ah, fuck. Sorry.
dsgrey
Kevin
2019 JLU
Backordered? I'd assume (maybe incorrectly) the o2 sensors would be common across the 3.6 platform. An engine that's been in production for a dozen years and used in many Stellantis platforms. I would assume they are a commonly replaced item based on engine volume.
garykk
Gary
Southern NM
2022 JLURD
Thanks for this. Why would my dealer say it’s on back order ?
Because they order from the factory, have to prove its a warranty and the factory doesn’t make any $$. Happens all the time with all manufacturers. Resellers pay cash.
alphawolff
california
2021 JLU
It's possible the dealer just didn't look at the correct part number. Sometimes parts supersede and the parts clerk misses it.
PJM86
Maryland
1986 Jeep CJ7
Employed
How Is a special order different when it comes to warranty items?
