JLanesey
- Joseph
- Mar 12, 2022
- Connecticut
- 2018 JL sport, 1954 CJ3B
- Occupation
- HVAC
I just replaced both of my axles with UD44 and M220 for rear.
I just installed Tom woods driveshafts front and rear and the installation instructions state pinion pointed at driveshaft.
With the control arms adjusted as they were factory the pinion VS transfer case we’re close to parallel,I’ve adjusted my upper control arms out about a 1/2” to get the front pinion pointed close to the transfer case. I can go farther but the reading I’m getting to the bottom of the Cs is approaching zero, the spreader holes are still angled back 8 degrees from being 90* from level. If I continue lengthening the uppers it will bring those holes close to 90 but then I think it would make the caster go to -6*?
I’m slightly confused so any help would be appreciated I’ll throw some pics below.
also with the double Cardan rear should I be adjusting my pinion angle up slightly back there as well?
