Upgrading Front D44 Axles vs. Buying Front UD44 Axle
CarbonSteel
CarbonSteel
2023 Ford Bronco Wildtrak
If you were welding long seams onto the axle maybe but the trusses for the JL don’t take so many welds and you don’t need to weld on the diff either
LOL - you are kidding right? What is the point of installing a truss that only welds onto the axle tubes? Why do you think there is pre and post heating required? The differential pumpkin is cast steel and yes, it is welded on to install a truss.
word302
Oregon
JLU
These labor swings may have to do with the difference between driving a Jeep up and bringing a removed axle in the bed of a truck. Just a guess.
Dropping an axle takes less than an hour for someone who knows what they’re doing. The welding process is a 4 or 5 hour job to do right.
BattleBorn
Las Vegas
2019 Jeep Wrangler Unlimited sport
Jeep Wrangler JL Upgrading Front D44 Axles vs. Buying Front UD44 Axle 3FC1325C-5089-4AFE-AF69-C48632B73FFE
Looks like Currie raised the price on these. $1,500 total.
OBJLU
Henry
Los Angeles
2018 JLU Rubicon
Oh yeah side of the diff absolutely but not the top, my bad but it’s minor welding, you don’t need to pre or post heat either, new material on these JL axles makes it unnecessary. I’m sure you have a different opinion, I’m only repeating what 3 very reputable shops who have done some big visibility builds are telling me. Mine was welded this way and it was perfect zero issues .
CarbonSteel
CarbonSteel
Had mine done a short while back and they definitely pre and post heated the welds to prevent them from cracking. "Cast" anything does not like sudden and rapid temperature changes and I would rather err on the side of caution than to have a weld crack down the road, but that is just me.
CarbonSteel
CarbonSteel
Ouch...guess COVID pricing strikes again. I am good with how mine turned out and the cost associated with it.
