Turbo 2.0 engine noise
Masonator
Pennsylvania
Sahara JL
I recently had my radiator replaced on a new ‘21 rubicon. I’ve also recently noticed this electric drill noise while idling in both park and drive. Sounds like it’s winding up then down. No performance issues. Just wondering if this is normal? Thank you in advance.
Masonator
Masonator
Pennsylvania
Sahara JL
Seems to only happen after the engine has been hot and running
Windshieldfarmer
Randy
Wichita, Ks
2015 JKU, 2020 JlU on order
I barely hear it…perhaps my hearing is not so good…or you are hyper sensitive. The idle sounds normal to me…like mine.
Heimkehr
Pennsylvania
2021 JLU 2.0T
Perhaps something was lost in the transition from real life to recording, but all I hear is an engine at idle. Nothing untoward is evident.
aldo98229
Aldo
Bellingham, WA
Market Research
My Jeep has the V6, but my 124 Spider has the Fiat 1.4T. The noise you describe sounds like the intercooler running to cool down the turbo.
I hear it in my Spider after I turn off the engine; if the engine is really hot it will run for 10-20 seconds until the turbo cools down and then it shuts off automatically.
I do not hear it when idling, though. The noise is not loud enough to hear it over the engine running.
Masonator
Masonator
Pennsylvania
Sahara JL
The noise didn’t translate to the video that well. It’s also possible that my hearing has become a bit sensitive to noise since I’ve already replaced the radiator. A fan or something to do w the turbo makes sense.
Although, I was just outside messin around and the noise intensifies when I turn the steering wheel. It’s lower when straightened but still comes and goes at regular intervals.
SecondTJ
Il
Jeep
1.4L IC is air-cooled, the 2.0L IC is water-cooled
hiimmike
2022 Jeep Wrangler JLUR
Network Engineer
I hear it, my hearing is pretty sensitive though. Sounds like someone is getting a cavity drilled. Couldn’t tell you if it’s normal, don’t have mine yet. ?
tecnic1
2021 JLR
My 2.0 makes a lot of weird noises, even for a turbo engine. I seems like everytime I drive it, I hear a new noise.
In fact, the only complaint I have with the 2.0 is the noises.
XJfanatic
El Paso, Tx
2020 JLU, 2020 JT, 2000 TJ
Can you narrow it down? If it’s coming from the lower passenger side of the motor it is probably the intercooler water pump.
mwilk012
2018 Ocean Blue JLU Rubicon
Service
I can hear it in the video. Sounds like a very high speed electric motor.
is it an electric pump for the inter cooler?
XJfanatic
El Paso, Tx
Yes it is an electric water pump. I never really listened for mine when running. That being said I can hear it clearly after shutting the Jeep off
jmccorm
Josh
Tulsa, OK
2021 JLUR
Systems Engineering
I couldn't bring up the video, but another source of a high speed fan might be headlights if you replaced them with an aftermarket solution that had its own cooling fan built-in.
