Trickle Charge JL Battery Recommendations
OldGuyNewJeep
Don
CT
Ormond Beach, Florida
Retired at 55 ..
Doh! AGM setting. Wonder what happens if you haven’t used that setting for charging. I guess I will find out since I haven’t..
From what I have heard/read..... flooded battery settings on a tender/maintainer/charger, typically overcharge AGM batteries.
Depending on the flooded battery charging profile on the tender/maintainer/charger you used, your AGM battery could possibly have taken a slight hit to a big hit in regard to it's overall life expectancy.
stumblinhorse
I got the “aux switches” message and used a Noco genius 10 a couple times which didn’t clear the message. then I disconnected the battery and did repair mode last time and the message hasn’t come back.
Retired at 55 ..
I myself do not use a maintainer/tender's repair mode for AGM batteries.
"'If you overheat a sealed battery like an AGM to the point they begin to vent you have permanently ruined the battery.
As a result with AGM batteries, sometimes a maintainer / tender's automated cycle works fine... but sometimes the recovery does more damage.... and sometimes it doesn't seem to help much. Just too many variables, so I avoid use of repair mode on AGM's.
[DELETED USER 82058]
Alabama
2022 JL Rubicon 2-Door
So reading through this, for the Noco 10 what setting is for trickle charge? 2022 with 1600 miles so thinking I may need this.
WiseguyDS
2020 Jeep Wrangler Unlimited Sahara
Since I deleted the Aux, and now reading these, I'm wondering at what point do you all think a charger is needed? What do you consider bare minimum use before you begin to consider putting it on a maintainer?
Retired at 55 ..
I bypassed the Aux on my JL over 4 years ago (2/19) before it was heard of/fashionable to do, like it is now a days....
I'm into lets say the battery thing on a JL, so I monitor 12v very carefully. I even have meters in play on the battery(s).
I watch watch 12v usage, etc.. Not because I am worrying but because I'm always in learning mode so to speak..
With that said... it all depends on usage of the usage of a particular JL/JT.
IF you do lots of short trips, lots of ignition and off's and little driving, you open and close the parked JL's doors often and wake up UConnect lots, etc., then you will want to consider using a battery tender/maintainer.. That's running with both Main and Aux of with just the Main only in play..
Pic shows my metered set-up. Meters, courtesy of @Jebiruph ..
Jeep Wrangler JL Trickle Charge JL Battery Recommendations 20230323_112026
WiseguyDS
IF you do lots of short trips, lots of ignition and off's and little driving, you open and close the parked JL's doors often and wake up UConnect lots, etc., then you will want to consider using a battery tender/maintainer.. That's running with both Main and Aux of with Main only in play..
That meter set up is cool. I like it!
Mine's my daily driver, but I'm retired so... the least I drive it is probably every other day at 7-10 miles each way. I also have a mod that keeps the ESS turned off. I've also refrained now from ever using the jeep in accessory mode.
Retired at 55 ..
You could for the next few weeks spot check voltage.. Use a meter or simple hardware like this.
I keep one of these around so I do not have to take out my pricey meter, say when I want to spot check voltage on the zero turn mower, tractor, etc..
Jeep Wrangler JL Trickle Charge JL Battery Recommendations 20230108_104106
Jeep Wrangler JL Trickle Charge JL Battery Recommendations 20230108_104031
BRuby
Skiing or Snowboarding
JLUR Benz Porsche-M Subie-M
Does it make sense to keep my Jeep on a trickle charger between starts? My daily trips are less than 10 miles and I usually get to where I'm going in less than 15 minutes. I have a motorcycle on a trickle charger and all has been good for 4 years. I just don't know about the pros/cons of a charger on the JL. Any help would be appreciated.
Short answer yes.
Long answer:
You will hear many anecdotal ideas what to do
This has worked perfect for us over the past 20 years
2 CTEK smart chargers + 4 NOCO smart chargers
Used on 6 different 12V batteries load tested
Oldest original battery around 10 yo - still fine
JL batteries OEM 5 yo - still fine especially the tiny aux
Do not charge different amp-hr batteries in parallel
Never allow your battery to ever fully discharge to zero
Since it will then kill your other JL battery in parallel
NOCO 5 is fine to use on the tiny aux
NOCO 7.2 or newer version 10 is fine to use on the main
Smart charge each battery separately as described
Regularly NOCO repair each of your AGMs separately
Have done this for years extending battery life
Just finished a 2000mi road trip in the JL
Batteries were perfect - SS always works after 1 min
Comprehensively research all this - then you do you
If you hook up as prescribed - expect no problems
My OEM main is slightly weaker than my OEM aux
JL forum is overall good - but some posts are BS
Especially to do with the 5 yr JL corrosion warranty
Battery comments by OGNJ however - seem spot on
Jeep Wrangler JL Trickle Charge JL Battery Recommendations 8A358A70-825A-469B-8AA3-FBBCFF2A8E42
SargeDiesel
Birmingham, AL
JTRD
Short answer yes.
Long answer:
Why do you say:
"Do not charge different amp-hr batteries in parallel"
I was under the impression that if you did, it would just take longer to fully charge each one, but would not cause any harm.
I keep a lead permanently attached to the main battery and just plug in the charger when necessary... I haven't had any issues so far.
Maybe you can explain ?
BRuby
Why do you say:
Yeah this has beaten to death in this forum
All battery companies do not recommend that
But many on this forum have their own opinions and believe this to be ok
In my personal experience - which I prefer - all my batteries last a very long time
So I do what I do
If you research this extensively you will come to own conclusion as well
Many here report dead OEM JL batteries - often multiple replacements
Me - zero - no problems - nothing
Hmm?
Anyways OGNJ and a few smart others have researched this with manufacturers
Coming to the same conclusions as posted
Hope this helps
SargeDiesel
Birmingham, AL
JTRD
So I do what I do
Hmm?
Hope this helps
Im with you... best to go off of manufacturer/self experience.
I have had most of my automotive batteries last 10yrs some more... but I don't have much experience with the dual battery set-up.
Time for a little more research... thanks for the help.
