Trackbar Product Selection Advice and Voting.
At the following price points which product would you buy or buy again?
  • Total voters
    217
SleepEatJeepRepeat
SleepEatJeepRepeat
Newport Beach, Ca
2021 JLUR, 2020 Audi Q7
Looking at Jeep stuff all day
Damn, you just cost me $100! While researching my answer, I looked at TeraFlex’s IR bushings and they are perfect for this application; their ability to rotate without binding should reduce wear and tear. They even have a lifetime warranty.
I was going to get a Rubicon Express trackbar ‘cause it should be a good quality trackbar with rubber bushings, but I really like the concept of TeraFlex’s rotational bushings for $100 more.
Metal Cloak’s screw-together bushings will be easy to replace, but I suspect TeraFlex’s bushings will require replacing far less frequently. Since I’ll keep my JL for 10+ years and do occasional heavy ‘wheeling, I’ll try the TeraFlex.
I have made my final decisions like 4 times today, until the wind blows again I am leaning towards the teraflex again :)
luckily I have a few more days till Black Friday
SleepEatJeepRepeat
SleepEatJeepRepeat
Newport Beach, Ca
So you got me researching teraflex it bushings
so you got me researching the it bushing and I found this great video.. final decision made again
TRZ
Tom
Denver, Colorado
2019 JLUR, Ocean Blue
A little more on this subject for the benefit of relative newbies to the sport. If you plan to do light wheeling or mostly pavement pounding, any of the options listed here will be just fine (though I still prefer rubber bushings).
I’ve been in this sport for 20+ years and regularly do stuff like in the photos where I push the suspension to its limits. In my experience, poly squeaks and has had a tendency to not bounce back (over time) from extreme flex, eventually causing thudding sounds as your suspension is exercised (on road and off).
Rubber bushings are quieter, but over time they’ll rip up due to extreme flex and require replacement. In my experience, this was every 25-30k miles, which I always dreaded ‘cause you need to remove all the arms (and perhaps track bars) and take to a place with a worthy hydraulic press (my 12 ton Harbor Freight press is not worthy) to have your bushings pressed out and new bushings pressed in.
Because of the above, I’m very interested in Metal Cloak’s screw-together bushing which should ease eventual replacement. But I’m more interested in TeraFlex’s non-binding bushings as they should hold up to my abuse a lot longer and thus not need replacement as frequently. I am trusting that TeraFlex has done their due diligence from a durability perspective, otherwise I’ll be back in the bushing replacement business.
Jeep Wrangler JL Trackbar Product Selection Advice and Voting. A138024E-9DF1-4780-9328-3180357DAEDB
Jeep Wrangler JL Trackbar Product Selection Advice and Voting. 1E15EFAC-0316-47DA-9D33-211CB4F2CD5A
KDR83
Krystian
Tampa, FL
2020 Punk'n Gladiator Rubicon
Which of these for a daily driver with very little trail duty, just want to recenter the axle and no noise.
SleepEatJeepRepeat
SleepEatJeepRepeat
Newport Beach, Ca
great input thanks for sharing your wisdom
GhosttheJL
Daniel
San Diego
2019 Jeep jl Wrangler 2dr
Synergy all day. Dual Durometer bushings, maintenance free, and rock solid I got mine a few weeks ago, night and day difference.
I bought a Yeti Pro (polyurethane bushing version). It took all the spongy feel out of the steering on my stock 2018 JLUR. Very satisfied. I have no other experience with products from the other makers other than Rough Country. My experience with their stuff for my truck was bad. I wouldn't buy from them again. Poorly engineered A-arms that didn't fit.
xeon
JLU Rubicon
I have the Yeti up front and a Metacloak on the rear....would have gotten a rear Steersmart if they had it. Regardless both work really well. But the Yeti is unbelievably heavy duty. Plan on swapping out the other parts with Steersmart as I can. Pricy but so worth it.
NPE102414
Peter
Pelham New Hampshire
2020 JLUR
All great products, but will come down to brand loyalty and future plans. I went with a Teraflex track bar and Teraflex adjustable IR front and rear upper and lower control arms, in my opinion they make the highest quality partd. For the drag link and tie rod I went with the Yeti. Again, cant go wrong with any of them. I would get a set of adjustable LCA’s and stay away from cam bolts.
I am going to replace the front trackbar, as my JL has the shimmy steering issue, also going to do a fabtech cam bolt kit to increase caster. But now I can't on which trackbar to buy and want advice.
Teraflex - looks awesome and I love all their products that I have - it's pricey
https://teraflex.com/shop_items/jl-jlu-hd-forged-adjustable-front-track-bar-w-joint-kit-0-6-lift?vehicle=JLU Wrangler Unlimited
Yeti - Seems well regarded on-site, but also pricey
https://steersmarts.com/products/yeti-xd-jk-track-bar
RockKrawler - Recmonned by my shop, looks nice and price is right, heard parts rust easy
http://rockkrawler.com/rear-adjustable-track-bar/
MetalCloak - Chromoly sounds cool, treated with a protective coating, and their bushing patent sounds cool. Good price.
https://metalcloak.com/durotrak-track-bar-solid-chromoly-front-jl-wrangler.html
Synergy - lots of good feedback, coated
https://www.synergymfg.com/synergy-jeep-jl-hd-adjustable-front-track-bar.html?category_id=4980
Rancho - good feedback on site, good price
http://www.gorancho.com/products/ac...ancho-front-adjustable-track-bar-rs62109.html
I am really leaning towards the teraflex due to being a fanboy and it can be adjusted on the vehicle, or the metal cloak because Chromoly is light strong less flexible, and it has a vibration-reducing bushing (not sure how well it works or if it's marketing junk).
But ultimately not experienced with any of these and feeling overwhelmed by marketing material, and want to get input from folks who have or have tried these products and can provide feedback.
So I created a poll showing the products, the delivered cost of each. I would love to see you guys vote, as well as leave comments on why you prefer or recommend a product. I am out of build budget, so I really want to save money and fix the issue, not looking for the dream part, just a solid part stops flex/vibration and recenters the axl.
(also if anyone thinks i should add another product to the convo let me know).
ll
SleepEatJeepRepeat
SleepEatJeepRepeat
Newport Beach, Ca
ll
I might skip cam bolts and just do track bar and the re evaluate, why don’t you like cam bolts?
word302
Oregon
JLU
They will slip over time. Once you slot out the holes in the LCA brackets they're slotted for life. Now when you go to put good adjustable LCAs on in the future after you're not happy with the cam bolts you have a slot instead of a hole to bolt them into.
SleepEatJeepRepeat
SleepEatJeepRepeat
Newport Beach, Ca
thanks for teachings me, will avoid them.. going to go teraflex front and a metalcloak rear tack bar.. and see how it goes, then do lca’s
No IFS
So Cal
JL Rubicon
I like the Teraflex best but have been waiting on them to release the rear version so I can get a matching set. Called a while ago and they said in the works.
SleepEatJeepRepeat
SleepEatJeepRepeat
Newport Beach, Ca
many idea of how long?
