jlewissystem
I plan on getting the 3.5 MC GC. Are any of you guys running that kit, replacing your front TB with a Yeti? Hoping to rely on the MC bar...unsure if there is a need for replacement.
Did you have death wobble with the MC kit or before install of the kit? I am trying to work the timing I guess.I have the MC lift and yeti track bar. I don’t want to come across as implying there is anything wrong with the MC, we just wanted full steer smart stuff when we had death wobble. The MC track bar is 1.5” solid chromoly I believe
The steer smart stuff is awesome. With I had gotten the griffin attenuator when we ordered but it wasn’t available yet
Brett
I have the MC 3.5" with their trackbar, Steersmarts Fliped draglink, tierod and relocation bracket.I plan on getting the 3.5 MC GC. Are any of you guys running that kit, replacing your front TB with a Yeti? Hoping to rely on the MC bar...unsure if there is a need for replacement.
Thanks for the response! So - sounds like you are still running the MC TB? That's good to know. I would assume that it's beefy...maybe not as much as the SteerSmarts, but i would think it would do the trick. Based on your review, i'll assume the SS TB is not needed, IF you get the MC kit. Would anyone else have a different opinion on this or agree?I have the MC 3.5" with their trackbar, Steersmarts Fliped draglink, tierod and relocation bracket.
I did have serious death wobble after the lift and 37" tires,
Between the Steersmarts parts, and an increase in tire pressure, it apppears the death wobble is gone.
The MC trackbar has plenty of strength and great bushings.
I had DW when the MC track bar was installed. I don’t want to imply that was the issue though. It drove great until our first wheeling trip and then the DW arrivedDid you have death wobble with the MC kit or before install of the kit? I am trying to work the timing I guess.
Interesting. Not sure if I had seen anyone else talk about DW post MC/RK lifts. Would not think their lifts would be an issue based on the designs.I had DW when the MC track bar was installed. I don’t want to imply that was the issue though. It drove great until our first wheeling trip and then the DW arrived
Brett
How is your flip link working? I am about to build the same setup with a MC 3.5, but steers smart page says not to use their top link with the 3.5" lift. You getting any frame rubbing?I have the MC 3.5" with their trackbar, Steersmarts Fliped draglink, tierod and relocation bracket.
The flip clears everything just fine.How is your flip link working? I am about to build the same setup with a MC 3.5, but steers smart page says not to use their top link with the 3.5" lift. You getting any frame rubbing?
After talking to both metal cloak and steers smart I decided to go with the under the knuckle setup. I figure if there is an issue I can change it up later. Metal Cloak did mention they are developing their own steering kit. It however won't be ready for almost 6 months. With my lift going on right after delivery, I'm not going to take the chance of crappy/wondering steering or DW in my first 5k miles. I'm just doing the steering upgrade right away. Cost of doing business I guess. I will be pairing the SS drag and Tie Rod with the MC Track bar. I don't see at this point why it wouldn't do the job exceptionally well.From my perspective and opinion I wouldn’t use the no drill top mount drag link from steer smart with a MC 3.5 lift. The bottom mount is perfect and my angles are great.
Brett
