track bar question- trying to diagnose DW
txj2go
DFW
My case of DW has gotten pretty bad- most roads will trigger it when I'm between 40 and 55 mph. I have just under 50k miles and do mostly highway driving but take 2 or 3 trips a year to do trails. The way it behaves and the ways I've tried to get it to stop have lead me to believe it is a track bar problem. If I'm on a road that doesn't trigger DW, or when I'm driving out of the speed zone where it occurs, the steering seems to be good with no looseness detected.
I did some checking today- ball joints, tie rod and drag link check ok. With the track bar I don't detect any movement at the frame end but at the axle end I detect a small amount of movement, not even 1/8", when turning the wheels hard left and right. I have not checked shocks yet. I expected to find a lot more slop in the track bar ends so I'm wondering of the people who discovered DW caused by track bar- how much movement could you detect?
AC77
AC Abegian
Los Angeles
Autobody , singer-songwriter
Hi
First thing make sure your lug nuts are all torqued to the correct spec
If you are on stock steering damper. Check for leaks and compression. By removing it and press it down with your hands. It should be super tight /solid (just be careful ) !
Are you lifted ? Or stock - Check your front and rear sway bar links. Check all control arm front and rear. Uppers and lowers
check your steering box make sure all 4 bolts are torqued to specs
If you don’t have a sector shaft brace. Get one it will make a very notable difference
my suggestions for now
also if you are lifted make sure your adjustable track bar is torqued on both ends
if stock. Still make sure the bolts are torqued
check your upgrades drag link. Or your factory one check it all out
txj2go
DFW
This is a JLU Sport. I have Rubicon takeoff springs, shocks and tires, plus Mopar LCA. The Rubicon springs lifted my front 1.5" and 2" in the back.
GoatHerder
Michael
Illinois
Jeep Wrangler JL Rubicon Recon Wrangler TJ
Study the mopar rubicon lift kit, seems like there is more than just springs. I am not the expert, but I think maybe a different trackbar and different control arms. Not sure what else, if you start replacing parts, try and determine if the lift kit needs different ones.
edit, just read post again and noticed that you have the control arms. back to checking torque specs.
Catiajockey
Jon
Melbourne FL
2018 JL Rubicon unlimited
measure the outside of your fenders to the edge of your tires on both sides. Try and determine if your front axle is centered or biased to the driver's side.
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
I solved mine with a JKS track bar and Fox stabilizer. Consensus is the factory track bar is too thin, and I found JKS was stout and reasonably priced.
Remorseless
NC
With trackbar-induced DW you'll see a good amount of play if it's a bushing failure (should be, generally, an obviously failed bushing - rubber tore up or bushing separating from the pocket or the bushing sleeve separating from the rubber). The other traditional cause of trackbar-induced DW is a wallowed out trackbar bracket bolt hole, but you should see it clunking around or the hole will be obviously oval shaped when you pull the track bar.
IMO, one of the tough things with the JL that I've noticed - at least anecdotally - is that the ball joints seem to pass pry tests even if replacing them with upgraded aftermarket ball joints resolves the issue. So I wouldn't be too quick to assume it's the trackbar, especially if you're on the OE ball joints and trackbar - the OE trackbar bushing is pretty soft and moves a lot even when in good condition, but the OE ball joints are junky.
yokramer
Snark Incarnate
Hows your caster
Bill007123
Bill
RI
2024 Rubicon X, 2 door MT.
DW is usually caused by combination of small wear / play at many or all components. Even if you don't see visible movement doesn't mean there's no wear. If your serious about fixing it right start by changing ball joints and any and all bushings tie rod ends, drag link ends, etc. . Trac bar will have some small movement in the rubber bushing, that's why it's rubber, however, any excessive movement will have to be corrected. When you fix the problem by just changing 1 component this is usually short live fix because now all of the movement is being supported by the 1 thing you changed and will quickly fail.
GoatHerder
Michael
Illinois
I was eyeballing synergy’s front end parts last night, would be a couple thousand for a complete ball joint control arms, links, steering bracket, build.
anybody done this?
jc1003
Jorge
Frisco Texas
2022 Sahara, 2025 Ram 1500, 2026 Hyundai Tucson Hybrid, 2023 Hornet
IT
anybody done this?
I recently did sector shaft brace, drag link, track bar, tie rods, and ball joints but I did Steer Smarts and Dynatrac ball joints. The difference is night and day. The tie rods are shot at 27K miles and ball joints you could move with one finger. My wife doesn't do any off road driving so I know the OEM isn't very good.
txj2go
DFW
I do a lot of offroading so mine have a good chance to get beat up, how can she beat them up so bad just on pavement?
yokramer
Snark Incarnate
those curbs at the mall didnt stand a chance.
txj2go
DFW
I've been trying to reason out what happens during DW. Considering the steering geometry- the track bar allows the entire axle to move to the right- the drag link pulls on the tires and turns them to the left, this pulls the axle back to the left. When the axle moves too far to the left the drag link pulls the tires to point to the right, this moves the axle to the right. Now the drag link pulls the tires to the left and the axle moves back to the left, and it basically vibrates back and forth. If there is slop in the drag link, tie rod, ball joints that should reduce the tendency to DW, basically allowing all of the parts to flop around on their own rather than acting in unison. The axle will vibrate back and forth at a certain resonance frequency. For me that is 40-55 mph. I have a friend with a completely stock Sahara who only drives highway miles and his started DW in the 70-75 mph range.
Nvdardx28
MA
2019 Jeep Wrangler JLUR
Electrical Engineer
This is about the only way to test the ball joints and if you made it that far you might as well change them.
