- Banned
What do you do for security when parking without doorsdo you run a dash cam? Also, has anyone installed this after switching to high steer? I’m running hydro-assist, so a raised bolt-on bracket won’t work. My concern is that the description says it shifts the bracket toward the center of the axle to clear the tie rod at full lock. I’ve always thought the track bar and drag link should stay on the same plane and be equal length for proper steering. I’d be pairing this with Reid high-steer knuckles and the Synergy drag link I’m currently using.
