Tncdrew
- Tom
- May 3, 2022
- East Tennessee
- 2022 JL Willys, 3.6L - 8spd
"Do I have to remove the axle too?"
100Do it right. Pull it apart and get it out if there.
I meant to say driveshaft"Do I have to remove the axle too?"![]()
He's referring to the transfer case and it needs serviced like any other transmission; just accidently dropped a piece of plastic in it is all.what's a transfer box? and why are you doing maintenance to it?
Look at the pic... that's a t-caseAre you referring to the transfer case or differential?
If the differential, you can pull the cover, clean out and re-install the cover which has a reusable gasket.
If you didn’t drive it yet I would clean out the drain pan and reuse the new fluid.
Transfer case?It’s in the transfer box
