Transfer Case shifter stuck in 4H?
Obus
Donald
NY
2021 JL Wrangler
I have a 2021 Wrangler JL e-Torque with auto transmission, and I cannot move the Transfer Case shifter. Does e-Torque have anything to do with this transfer case shifting?
calemasters
Allen
Springfield, Mo.
2026 Moab 392 w/27X package & Escalade
Retired Mechanical Engineer
No, I dont think so. Which transfer case do you have; Command-Trac or Rock-Trac?
flick2614
Randy
AZ
2021 Jeep JLU Rubicon Diesel
Is the shifter moving at all? Any warning lights on the dash? have you gotten underneath to see if the front driveshaft spins freely? Can you move the linkage from underneath?
Need more details here.
Obus
Donald
NY
2021 JL Wrangler
What ever came with JL Sport in 2021.. The Jeep is stock.
Obus
Donald
NY
2021 JL Wrangler
The shifter will not move at all. But I pulled on the stick while a friend pushed on the rod to the case it went into 4h and the dash confirmed 4h. When I moved the shifter back to 2h is went back to 2h easily.
  • Like
Reactions: Gio
Gio
Gio
MN
24 Willys XR 2.0,
E-Torque should not have anything to do with it.
Can you drive? Forward or reverse while still locked into 4-HI?
How are you trying to disengage it? Are you moving or stationary?
Can you shift into neutral and depress the brake and try that method?
More details as to what you've tried may help.
flick2614
Randy
AZ
If it is shifting from moving the bottom linkage but not the actual stick you likely have a break in the cable. Take the trim piece off and check the linkage up top.
Obus
Donald
NY
2021 JL Wrangler
The Jeep was on a lift when we got it to shift and believe the front wheel turned. I will try the neutral, brake method again. Thanks for the help.
  • Like
Reactions: Gio
Gio
Gio
MN
24 Willys XR 2.0,
Best of luck.
oldcjguy
Jim
Central FL
16 Challenger Hellcat, 19 Challenger Scatpack, 20 JLUR Recon
Software Engineer
Are you moving when trying to shift into 4H? Try rolling forward slowly and pulling on the shifter. Sometimes it takes a little movement for the gears to mesh
WXman
Central Kentucky
Yep ^^^ and that's especially true when shifting in/out of 4 Low. Gotta' be moving at 2 to 3 MPH when you make the shift or you will risk breaking the linkage.
Obus
Donald
NY
2021 JL Wrangler
Thanks.
