THAW
- Foster
- Oct 28, 2022
- PNW - prefer Middle of Nowhere
- 23 JL4DrRubicon
It's ~300 lbs for the battery, ~700 lbs additional overall compared to the more typical engines. And any weight above the axle is not going to help handling.It's actually only about 300 more pounds or one fat dude than the diesel. The 4xe gets the gladiator axles, same rear brakes as the 392 which I believe are bigger and I'm assuming some chassis upgrades. The low cg actually makes it handle better on and off road as it's less tippy though. You can go with more lift but keep the cg close to a less lifted regular jeep or lift the same amount and have an even lower one.
300 lbs is 300lbs, but 300lbs is such a small fraction of the total weight it really doesn't move the needle much in one direction or the other as long as the vehicles suspension is set up for it.
