4xFUN
- Mike
- Dec 9, 2019
- Scottsdale AZ
- 2024 2-door Ruby-X, 2020 2-door Ruby, 2023 RAM TRX
Couldn’t care less about the vehicle value.
does anyone know of the new box is any different than adjusting the steering box? Or is there also calving in the box?
the price of the AE box is now 250$ from a Mopar authorized dealer. My time is worth something. I may just replace myself.
dealer already denied my claim unless I want to return vehicle to stock and remove steer smarts linkage.
anyone know the Mopar estimated install time for a steering box?
Are there any other dealers in your area? If the Steer Smarts gear is installed correctly (make sure the red taper sleeves are fully seated and everything torqued to specs) a competent service director, service manager, shop foreman or even a good service writer should be able to cut through the BS and offer assistance. (I used to run a large Mercedes service department and was with Chrysler prior to that...Before starting my own business which is not automotive related) Before you go to the new dealer, make a folder including all the times you have complained about steering-what if anything the other dealer did to address those complaints, what you did out of your own pocket (Steer Smarts, alignment, tire rotation, adjust tire pressure, etc) in an attempt to solve the problem. Also take several screen shots from this forum of complaints, Star cases and where the problem was diagnosed and solved by replacing the steering gearbox. Good luck!
PS: Make sure you do not go in with a Synergy Sector Shaft Brace attached to the gearbox...
