Start Stop battery out again
Steph1
Steph
Quebec, Canada
Jeep JLU , Audi Q5
Why dont you just install an underhood charger and plug it in when you’ll be a few days without using the Jeep or you only have short commutes coming up.
Been over a year now since I’ve done so and never had a problem again. My S/S always works immediately as soon as the engine gets up to temp.
If interested, just do a search in this forum and you’ll know exactly what to buy. Otherwise, let me know and I’ll help.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
I didn't bother to warranty my bad aux battery. All they do is replace it with another junk battery that will fail quickly.
I replaced mine with quality aftermarket batteries. And I run a trickle charger when it sits for a while.
dchemphill1
dchemphill1
Nebraska
2020 Wrangler Rubicon Recon
School Administrator
Thanks for all the info...maybe I will replace both. What is the best method to get to aux battery? Heard two ways and both say it is easy. Recommendations.
Chupacabra
Greenville, SC
2021 JLU
My aux battery went off like half a year ago. With that, so did my auto start/stop. Never a problem until this past Sunday. My car wouldn’t start, just took it in to my dealer today and since I bough it pre-owned , sadly the battery wasn’t under warranty. Now I have to pay $1300 to get both batteries replaced, plus the battery sensor. Sucks .
Both batteries cost me about $350, replacing them is not difficult. If the IBS is bad, that's a $55 part. Who is charging you $1,300 to replace both batteries? That sounds way too expensive.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
Mine is the diesel so there's only one way for me. It's under the main battery in a closed compartment with a lid. Not sure about the gas versions.
Bill_P
Bill
Orange Va
2018 JLU, 2023 JLUWSXR
Can't tell you..shhh
That's a rip off. Go buy the batteries and change them out yourself for about 4-500 bucks. Chances are high that your battery sensor isn't bad. Someone else here had a dealer that told them the exact same thing the other day.
Fudster
Elliot
Athens, GA
2019 Sahara
Fudster
Elliot
Athens, GA
2019 Sahara
The main battery was load tested and good in January...
Do note, if a load tester was put on the main battery and the negative cable from the Aux wasn't first removed, your load test was one that represented a composite test of both batteries, not the main battery.
@Rhinebeck01's way. Make sure you have extra fender clips. You can get to the battery through the top and not break fender clips but you might break more expensive to replace components.
https://www.jlwranglerforums.com/fo...ent-the-easy-way-pull-the-fender-flare.56807/
roaniecowpony
Retired Engineer
If you're willing to spend $1300, you may want to consider just biting the bullet and installing a dual Genesis battery system.
Fudster
Elliot
Athens, GA
2019 Sahara
IMHO the Genesis dual battery system, while excellent, is best left to those who desire power management for their after market appliances, particularly power hungry ones, and particularly when used in overlanding situations.
Yes, it will solve issues with the factory Aux battery, but so too, if you're willing to do without ESS, will simply disconnecting the Aux battery. To use the Genesis kit so you can run ESS is both IMHO overkill and cheaper methods, like trickle charging might be more effective.
To the "4" people out there who like ESS, ironically enough, the Genesis dual battery system will limit you to 6 ESS events per engine crank. While this may be more ESS events than many people experience in one trip, things happen this way because when the dual battery JL sees that the cables which normally connect to the Aux and main batteries from the factory have,--now connected to the Genesis setup--the same voltages prior to an ESS event, (which is what happens with the Genesis kit,) after 6 times of this it assume there some miswiring, and turns off ESS until the next cold crank.
roaniecowpony
Retired Engineer
Just tossing it out there, since most Wrangler owners will at one time or another do some type of off-highway trips and these "electric marvels" can benefit from the redundancy.
Fudster
Elliot
Athens, GA
2019 Sahara
Certainly there are people out there both fed up with their Aux battery AND in need of overlanding power. :)
dchemphill1
dchemphill1
Nebraska
What brand do you recommend. I think I am going to replace both.
Buster1
Ft Worth, TX
‘51 M38
Those that have had the Aux Batt fail…. What are the symptoms? How do you know it’s failing? I’m just curious to know what to look for if it should start to happen to me. Thx!!
