Durango18
Not sure if thats the same issue,you could have a pulley or belt worn.I have the same issue. I also hear a similar squeal or whine noise when I accelerate. I have about 13K miles on mine.
Havent heard it for a month or so,light pressure100%Noticed the squeal, will try light pressure tmrw and report back!
Find out who previous owner was. 2018 with only 7000 miles, maybe somebody’s buy back for problems and resold to you!Hi everyone - just got my JLU 5 days ago with 7k on it. Mine squeals LOUD & it happens whether its my autostart or if I'm starting it myself. Are your guys' sound going away shortly there after starting it? This is my first Jeep and between this and the display problems I'm having it is super deflating for this being my "dream vehicle". All help is appreciated here.
(Side note: what is ESS? Electronic start/stop?)
Thanks fam
I bought it CPO from a dealership and the vehicle history came back with no red flags. Not sure if this helps?Find out who previous owner was. 2018 with only 7000 miles, maybe somebody’s buy back for problems and resold to you!
Thank you! It's been below zero in my neck of the woods for weeks now so I'm starting to wonder if that doesn't have something to do with it. Warmed up to about 0 degrees F and the squeal is much quieter and intermittent now too.@theroamingcolt ... you are still under warranty. Take it in for service. If it's as loud as you say... something is not quite right. I get the squeal very intermittently, and it's not all that loud.
Tough=touchGood thread. For those who don’t read then barely tough the brake when you start it and you should have no squeal.
Hi. This was posted somewhere else here. The fix is simple. Push the brake in and let your foot off it - as it's coming up, push the start button. There will be no squeal. Takes a bit of time to get the timing right, but it solves the issue. Try it!
Its most probably got to do with the vacuum pump/brake booster's designWell the dealership gave me an "answer" they said that it is normal for the squeal noise upon first start up when its warm caused by the belt.....
Then why does it not happen when i take my foot off the brake when i start it?
Has anyone found the root cause of the squeal yet? I't pretty sure its not the belt?!?!
