Squeal at start-up
HardRock
Beverly Hills, CA
2015 Rubicon JK Hard Rock Edition (FL); 2018 Rubicon JL (CA)
I have a squeal and a thump. Took it to my dealership today and got the expected reply: "Couldn't reproduce the problem." When I pressed them and showed them, they said, they "feel at this time, the noises heard are normal condition only at this time."
Be grateful if you have a dealership who actually admits there's a problem. Most dealership service departments are mindless parts replacers. Diagnostics is a dwindling art. If there's no TSB (or the guy working on your car that day isn't particularly good with computers or numbers), the problem does not exist.
For fun, here's a montage of my startup noises.
LOL - Love it!!!!
JJexp
Jon
Hatboro, PA
19 Raptor, 68 Y body coupe.
G650 driver
I’m almost certain that the noise we’re hearing is coming from the starter. Back when I was a flight instructor, the school I worked for had 45 or so airplanes. Six of them were Grumman Yankees, and they all made the same sound as our Jeeps.
When starting the engine, as you moved the key from start, the engine would squeal. The noise was the result of the starter being deenergized, and the starter solenoid retracting. Specifically, it was caused by the friction from the starter gear rubbing against the flywheel gear teeth while retracting that made the noise.
TaiMc
Tai
Houston, TX
www.instagram.com
'18 JLU Sport Mojito!, 3.6L & '18 Ninja 400 KRT
Communications Manager
hehe love this explanation and description. Cool! :sun:
brandonh
Brandon
2005 dodge 1500 , 2008 town and counrty, 2003 town and country
Hey Everyone,
11,250 kms in and I have the same "belt squeal" at start up. Seems to more pronounced as the weather warms, however could just be that the windows are down. It's actually an embarrassing sound, sometimes louder than other times. If anyone has had this diagnosed, the info would be helpful. I have the first JL in my town and I fear the Service Department or the technicians will have no clue about repairing it. I refuse to believe that is a "normal" sound as some have suggested.
Thanks,
This is not Normal, please don't let and dealership tell you that is. They are only saying that because they are to incompetent to fix the issue.
brandonh
Brandon
Hey Guys I personally haven't experienced this noise, but from the explanations and the Youtube videos I have watch it sounds to me like as soon as the engine starts up the squeal happens then immediately goes away. This could be from the actual starter not retracting the plunger (small gear) quick enough therefor its in a overrunning condition. kinda like on an older vehicle if you were to hold the starter after the engine had started. The starter would actually be engaged. I think this could be happening for a split second therefor causing the noise. NO gaurentees. Has anyone with this problem and had the starter replaced. I did see that someone had the flex plate replaced but no fix. The reason for that is the dealer though that the flex plate was cracked maybe , we have seen this in other Powertrain combinations. but thot the 3.6/ZF
FWB FL
LArry
Fort Walton Beach Fl
2018 Wrangler JL unlimited
same noise, oddly enough-- when the ess is active at a stop light, and it turns back on; no squeal.
It's only from the first startup does it do it
I agree with you the exact same issue with mine on first start.
Josh903
Josue
Plano, TX
2018 Wrangler JLU Sport S
Mine with 650 miles does the exact same sound. Only after letting it sit for at least 15 minutes after having driven it. Doesn't do it on cold starts.
Tylerjcloud92
Tyler
2018 JL sport
I’m more concerned with the loud ass thump mine does the same thing and you can feel it in the seat.. did you ever get anywhere with this at the dealer?
xpsruler
2018 JL Wrangler Sport
I experimented with my vehicle a bit and believe I found what the noise is related to. In my vehicle it only seems to occur when the brake pedal is pressed upon(such as when starting the vehicle from inside but not remote start). If I put hardly any pressure on the brake when starting then it doesn't do it either.
bikenutty
Cash
Anaheim
2018 JLUR - 2018 Raptor - 2021 Tuono - 2018 NC750X - 2015 Yamaha 212SS Jet Boat
Facilites Manager
could be a hydraulic or vacuum noise? I have it too now for 4000 miles. also hear what sounds like cam chain or variable cam timing noise on startup after eng has been off enough to loose oil pressure.
Tintop
Stu
Wrangler JLU Rubicon
Great find. I tested this with mine and got the same results. Zero squeal when the brake isn't pressed. Interesting.
RubenZ
Ruben
Deep South Texas
cyberrube.com
2018 Silverado 2500HD Duramax, 18’ Toyota 4Runner
maybe pressing the break and engaging the motor is causing some pressurization on the break system at startup. I too have this sound in my SPORT and it makes the vehicle sound cheap. but Its VERY FAST and I hear it more on cold starts than warm.
Swanny297
NELA
2018 JL
It has worked for me I barely keep my foot on the peddle after hitting the ignition button and haven’t had any squealing - I would here it every morning but haven’t this week since I started this.
Lou_JLU
Louis
Adirondacks
2018 JL Wrangler Sahara, 2019 JL Wrangler Sahara
I've tried your startup procedure and have had no high pitched squeal or the occasional clunk sound at all this week. Thanks!
I'm guessing that a firmware update will resolve this issue since the computer controls everything. I am hopeful that Jeep issues a TSB for it.
