Speaker issue?
Wrangles
Arkansas
2018 JLUR 3.6 6sp Billet
The vibration is the metal bracket where the module is bolted in. Take four rubber grommets where the bracket is bolted in, 10mm I believe, and put in between bolts and bracket. Takes care of it. It's worked on three JL's at my dealership sofar.
Don’t think it’s possible to get at 2 of the 4 bolts on the far side closest to the door without taking off more than just the center lower panel under the steering wheel. I looked and could not even see those two bolts or even get a finger in there to feel them.
If you have some other way to do it without taking out the dash or taking it apart further let us know. I was planning on heading to the store to get some rubber washers but when I saw how it’s mounted I nixed that idea.
Wrangles
Arkansas
As others have done I used a business card folded in half. I put electrical tape on the card and wrapped each end to thicken and harden the edges of the card. I contorted my body and arms and used a long flat head screwdriver to wedge inbetwen the gateway housing and its outer housing before then shoving the card inbetween as well.
It works. Charlie Brown sound gone. I left the panel off as my JLTaserLite arrives on Monday so really no need to wear out the plastic tabs on it pulling it off and on over and over again. Be forewarned you will be cursing FCA for making you contort your body into a pretzel.
Tip on pulling that panel off though. It’s on tight like a tiger. Start bottom left corner and slowly pull while increasing the pull, but slowly. It’ll let loose just have patience. Then go up and do the same then around on the other side. It pops out pretty fiercely. Key is pull slowly don’t just yank the hell out of it. Don’t worry though if you break it I looked it up, it’s like a $25 part.
I will wait until there’s a Jeep TSB on the issue to see what they recommend as a fix. Either way a dealership won’t be touching my Wrangler for this. Those goons will end up tearing the whole dash apart and it’ll never be the same afterwards.
stoowie
2018 Jeep Wrangler JL
Funny I folded the business card twice and contorted my body with a mini flashlight in my mouth and was able to shove the card in place. and VIOLA! it worked
OldGuyNewJeep
Don
CT
These help with the panel, a LOT:
KINGLAKE Auto Door Clip Panel... https://www.amazon.com/dp/B00HNMLQAG?ref=yo_pop_ma_swf
melendez69
Marc
Waxhaw NC
...huh?
Mwah mwah mwah, mwah mwah mwah mwah. Mwah mwah mwah mwah.
*Translation: same here... .I jammed a piece of cardboard in & left the panel off. I'm also expecting a Tazer Lite arriving Monday & I can't wait to twist around under there... again.
OldGuyNewJeep
Don
CT
Some pictures to help you guys understand the business card fix (way easier than rubber washers - can’t see how you’d do that without taking the dash apart).
I used a long, very skinny flathead to make enough room to slide in a little square of cardboard. Rather than a business card, I used some cardboard from Harbor Freight glove packaging - thicker and harder (that’s what she said!)
I never had the speaker issue, but I do have a very annoying (to me) vibration sound that I swear is coming from behind the vent or from inside the a-pillar. You guys got me wondering if it is the SG module rattling, so I figured a bit of contortion and some cardboard was worth trying. I haven’t gone out to test, yet. Fingers crossed!
Jeep Wrangler JL Speaker issue? 704495BD-9347-4F44-8103-6937CCBEE2DC
Jeep Wrangler JL Speaker issue? 42F8F444-2DA2-4E4C-A95F-53E08D21289B
raskal406
Bryan
Billings, MT
2017 Rubicon JK
I'll post some pics tomorrow to show what I'm talking about.
stoowie
Raskel,
In my opinion placing the business card doubled over seemed to correct the issue.
buckinoff
Jen
ohio
2018 JLU
After having 3 speakers replaced and my jeep into the shop 5 times with no fix. I FIXED IT! no more Charlie Brown voices!!!! Shoved a whole bunch of door weather proofing stop around the entire speaker module (drivers floor). I am so excited!!!!
