SOS- at dealership now! Programming Gears
Chuggy
NC
18 JL Sahara
Anyone had their regears done and had the dealership program the gears? After a swap, not a replacement. They are saying they can only program the gears for the replacement with same gears, they can't program with a new gear ratio. Help!
maestro5531
Paul
IL
22 HydroBlue TRX , 23 HydroBlue JL Willys
They can be programmed but the idiots are clueless. You can also do it using JScan, Tazer, or AlfaOBD
roaniecowpony
Retired Engineer
Chuggy
Chuggy
NC
18 JL Sahara
Run away as fast as you can and get this to a shop where they know what they're doing
I can't run away because my *manual* jeep won't go over 20mph because the computer is confused. Regear done over the weekend and towed here to program the computer
Chuggy
Chuggy
NC
18 JL Sahara
If you can use a PC on forums like this, you can use the phone app, JSCAN. JScan – OBD JScan – Mobile Jeep, Chrysler, Dodge Diagnostic Tool
I looked into jscan and liked it over tazer, since I don't care about all the foo foo stuff and just want my gears and tires programmed. But I came here hoping the dealership could program it permanently in the build sheet like a tattoo. Also Im now screwed since if I go with an aftermarket doohickey I'm still out of a vehicle for a couple days waiting for it to arrive
Jaym
Salt Lake City
2018 JLU Rubicon
Who did the regear? Can you take it to a competent 4x4 shop?
Chuggy
Chuggy
NC
18 JL Sahara
Would love if a tech here could chime in on how to do it. They are saying the "sales code" is not offered for that trim. Some red tape BS in the computer
Fatboy97
N.C.
2 Door Rubicon JL
Go buy yourself the ECRI programmer. That is what I used and it really is beyond simple. If I can do it anyone can. It’s only around $120.00
Chuggy
Chuggy
NC
18 JL Sahara
Potentially. I am looking into that. I had it done by at someone's house that has a lift, tools, etc. The regear job went smoothly but they I guess didnt have what's necessary to reprogram things. And to my knowledge the dealership is the only one that can do a permanent program for gears/tires. So we just went with that.
Chuggy
Chuggy
NC
18 JL Sahara
Do I need anything in addition to that?
Fatboy97
N.C.
2 Door Rubicon JL
Not at all. Go to the website, it explains everything. It works with your phone using the app. I also used it for speedometer correction after putting on new tires and wheels. It really is very easy to use. I went from 4.10 to 4.56 super easy to use.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
I'm confused. You took it to the dealership to get that detail onto the build sheet??? Yet you did the gear change at someone's house?
Note that the build sheet can't be modified.
That makes zero sense. Are they claiming to only be able to reset it to stock? Ask if they ever install different gears in Jeeps since they need to reprogram those.
It sounds like it'll be days before this is resolved at that dealership. Seriously consider getting a Tazer or JScan and do it yourself. Or taking it to another dealership.
Note that the Jeep shouldn't be going into limp mode for this. How much of a change in ratios did you do?
Chuggy
Chuggy
NC
18 JL Sahara
From 3.45 to 4.56
maestro5531
Paul
IL
Dealership is trying to modify Sales Code on the Build sheet instead of simply changing gear ratio in the ECU. If OP ever gets any Updates / Flashes it would go back to stock gear ratio which would have to be recalibrate again. Same with tire size.
It's beyond me how someone would regear a diff , yet doesn't have a 100$ scan took to change diff ratio in ECU.
