SOS- at dealership now! Programming Gears
jellis4148
Missouri
2019 Jeep Wrangler JLU Rubicon
They 100% for sure can program. Why the hell would they need to program if the ratio stays the same? I work at a CDJR dealership, and asked my service manager if it could be done.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Dealership is trying to modify Sales Code on the Build sheet instead of simply changing gear ratio in the ECU. If OP ever gets any Updates / Flashes it would go back to stock gear ratio which would have to be recalibrate again. Same with tire size.
It's beyond me how someone would regear a diff , yet doesn't have a 100$ scan took to change diff ratio in ECU.
I haven't heard of someone getting an update / flash and having their gear settings reset (Tazer excluded, of course).
Yes, that would be "horrific" in that they'd need to put those numbers in again.
I'm thinking OP isn't communicating well with the dealership due to asking for things like the build sheet to be changed.
Chuggy
Chuggy
NC
18 JL Sahara
I suppose in the event of doing a repair/replacement where they have to reset the pcm or something of that nature? I have a basic grasp on how that works but I'm no tech so I kind of get what they are saying. I'm going to call another shop.
maestro5531
Paul
IL
22 HydroBlue TRX , 23 HydroBlue JL Willys
If someone modifies a gear ratio from 3.45 to let's say 4.56 themselves, Stellantis still has original build data and sales codes on their end. Depending on the update/flash it's possible for the dealership to flash the ECU and revert everything back to stock. Had this happen on my TRX that I retrofitted with Passive entry, lane keep assist , adaptive cruise, tire size. Went in for a recall and everything was wiped back to stock.
cgagnon99
Maryland
2021 JLU Sport Altitude
Like others have said, if you're asking them to "add it to the build sheet" that is different than programing gears and the gears shouldn't need a sales code. Just like them changing tire size for folks. Honestly you're better off getting a tazer and being done with it. JSCAN is nice but takes a little more effort/less guardrails vs tazer just plugging in and going (I have JSCAN and it's perfect).
Once you get this squared away I'd love your thoughts on the 4.56. That's in my plan on my manual JLU Sport as well.
roaniecowpony
Retired Engineer
JSCAN will set the gear ratio "permanently" until the PCM/DTCM is over-written to change it. You won't need to leave JSCAN connected. Same with your tire diameter and all the other selectable changes JSCAN offers.
jellis4148
Missouri
It's the same as them changing tire size. They open an R.O. with the sales code for gears that way they tech can pull it up on the computer. They go through the options, update the computer and done. It would show on the build sheet 4.56 gears.
Chuggy
Chuggy
NC
18 JL Sahara
I'm on Amazon now looking at the cable/obd adapter
Chuggy
Chuggy
NC
18 JL Sahara
Right, should be simple but they are saying there is not a sales code for 4.56 gears for my model/trim, or they don't know where to look for it
Chuggy
Chuggy
NC
18 JL Sahara
I'll definitely update! I'm looking at doing jscan now as it's the most cost effective at the moment. I really only need it for gears/tires so Im good with that over a tazer
Chuggy
Chuggy
NC
18 JL Sahara
Easy partner. When I called around for quotes and what was needed not one single person said "hey make sure you have this doohickey first" or I would've been prepared. Actually the dealership prior to the work being done, told me they could permanently program my gears after the work was done. So I proceeded with the information I had.
I'm looking at my options on Amazon though.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
The High Tide is a Sport S, and will have 4.56 gears.
Also, find a model on the lot with an XR package and see if they can ise the VIN from that to get the computer to accept the gear ratio change. If they don't have one on the lot, find one for sale online.
Chuggy
Chuggy
NC
18 JL Sahara
How does this work if it is utilizing a vin from a different vehicle?
maestro5531
Paul
IL
I was not talking about you, you were paying for a service which the "shop" did not fully complete. I was talking about a mechanic that will do the work but tell you to get it programmed somewhere else. It's not engine tuning. This takes 2 minutes to change gear ratio when you have a Bluetooth obd plug , 10$ JScan and 10$ Security Bypass Cable.
