Something is wrong...
Goheels050917
Dustin
Raleigh - Durham, NC
2018 Jeep Wrangler JLU (SOLD - March 2021)
SD-WAN Engineer - Technical Author
So I have the 2.5 RC spacer lift on the jeep for about a year and half and all is going well there. I added Fox 2.5 shocks last week (which seem to be better than the red Rubicon ones I just took off).
The problem is when I hit a speedbump or any hard bump, the back of my jeep seems to hit HARD almost like its hitting the bump stop.
Do I need longer springs also?
Goheels050917
Goheels050917
Dustin
is everything tight?
just riding around seems okay, but any bump (like hitting the usual bumps where roads connects to bridges) or speed bumps (i go slow) its like WHAM...
the only thing that is still factory is my springs at normal height...its gotten worse with my longer shocks...ALOT worse
scrape
ca
Fiat
Are these the 2.5 shocks that come with the mopar lift or 2.5 race series reservoir shocks?
Goheels050917
Goheels050917
Dustin
scrape
ca
Fiat
So just to be clear, you bought the 2.0 shocks you just posted a picture of. In the OP you said you bought 2.5 shocks.
Goheels050917
Goheels050917
Dustin
Sorry man, may have been a typo. These are for lifts 2-3inch. But I have a 2.5 lift...RC spacer lift though.
irishtim7
Tim
Cleveland, OH
19 JL Wrangler Rubicon, 02 BMW M3, 91 BMW E30
Since you were running OEM shocks, you must have had shock spacers. Did you happen to leave those in when you added the FOX shocks?
Also, let's see a pic of the rear so we can see what's going on.
Goheels050917
Goheels050917
Dustin
To be honest, I am not sure. I had a neighbor install (has his own auto mechanic business) I didn't ask. Should they have stayed?
scrape
ca
Fiat
No. If they were left in, the shock will sit pretty deep in the stroke, and bottom out during compression. You should go check to make sure, and if you don't know what you're looking for, post a picture of your rear axle where the shocks bolt up.
irishtim7
Tim
Cleveland, OH
No. Not if you have shocks for 2-3" of lift. if the shock spacers are still in there the shock would be too compressed and have no uptravel. Kind of sounds like what's going on. It would bottom out pretty quickly.
Goheels050917
Goheels050917
Dustin
Jeep Wrangler JL Something is wrong... 20191105_103820
Jeep Wrangler JL Something is wrong... 20191105_103826
irishtim7
Tim
Cleveland, OH
Yep. That's the problem. Those spacers on the bottom need to come out. Make sure they come out on the front too.
Hopefully you didn't damage the shocks bottoming out.
Goheels050917
Goheels050917
Dustin
*sigh*, well it totally makes sense now. Nah I think they are okay.
Couple of questions.
1. Will I lose my lift back there taking these out?
2. Do I need to jack the jeep up, or what is the procedure on removing them?
Thank you all for helping and diagnosing so quickly!
irishtim7
Tim
Cleveland, OH
1. No. lift height is not determined by the shocks.
2. Yes. You will need to droop the suspension to get the shock to line up with the mounting holes. Unless you're super ripped and can compress the pistons by hand. ;)
AlexJeepVB
Alex
Virginia Beach
2019 JL Rubicon 2.0T eTorque
You can remove all 4 shock extension brackets on the ground, no need to jack the jeep up, not that hard to compress the shocks. Make sure you get the fronts as well. The exension brakets are just on the bottom mount of all 4 shocks.
