Skyline LED Tail Lights issues
JLTony
Tony
Michigan
2019 Wrangler Unlimited 2.0
I've got a 2020 Sport S with halogens. Installed Skyline LED taillights and they are doing some strange things. Here's a video of what they are doing
Sometimes the left taillight does this non-stop, sometimes the right, sometimes both. I have a trailer wiring harness installed also. Not sure if that has anything to do with it? Anyone else have this problem? Extreme Terrain won't allow me to send them back because they were open box and I'm outside the window of return.
Any help is appreciated.
Thanks,
Tony
JLTony
JLTony
Tony
Michigan
Also it only seems to do this while the engine is running.
Will_Jeep
Will
Atlanta
Black 2108 JKU Sahara, Black 2016 Mercedes CLS400
Do they come with an inline resistor? I’m not familiar with that brand but when replacing other incandescent lights with LEDs, I’ve seen some odd behavior.
JLTony
JLTony
Tony
Michigan
Hi thanks for replying. They have a built in resistor. They are supposed to be plug and play. I attached a picture to show what they look like
Jeep Wrangler JL Skyline LED Tail Lights issues Screenshot_20210116-162032_Chrom
Will_Jeep
Will
Atlanta
When it’s doing the chase effect, are you turn signal/blinkers on, or it it just the tail lights?
Also, do all functions work as expected when the engine is NOT running?
JLTony
JLTony
Tony
Michigan
Just the tail lights.. It only does the chase effect when the engine is running and my running lights or headlights are on. If my headlights/running lights are off the lights stay off completely. The blinkers work fine and dont seem to have any effect on the issue. But once the blinker is off, it starts doing it's chase thing again.
It seems like the chase happens when I first turn my headlights on for one cycle around the tail light. Like the lights are doing a quick self test at start up. It almost seems like when it does the continous chase it may be stuck in a self test mode. I might try to take everything apart again and check the connections. Maybe put some dielectric grease between the connections.
Dan M.
Albany NY
2020 sport (2 door)
If I pulled up behind you and saw that, I would assume you did it on purpose. I've heard when changing to LED headlights you sometimes need a re-flash from the factory or you can buy a taser and do it yourself. Not sure if the same thing would be neccessary for tailights.
calemasters
Allen
Springfield, Mo.
2026 Moab 392 w/27X package & Escalade
Retired Mechanical Engineer
Do you have the OEM trailer wiring harness or did you install the harness aftermarket? Other than the tail lights, is there any other electrical mods that would affect the LED tail lights?
You may want to do a pin out check to make sure the terminals are inserted into the correct cavities on the tail light connectors. Will Extreme Terrain provide you with any tech support? It would be nice it they would send you a pair of "known good" lights to test.
Maybe your open box lights are defective.
JLTony
JLTony
Tony
Michigan
I just started looking into doing a reflash with a taser. I dont know much about the taser programmer yet.
Its weird because sometimes the lights seem to work perfectly.
The harness is an aftermarket harness. I do have some aftermarket LED headlights. Maybe that is causing some problem? Extreme Terrain basically said too bad, and suggested I contact the manufacturer.
JLTony
JLTony
Tony
Michigan
What is a pin out check? Would i just take apart the connections and make sure there are no bent pins etc?
Thank you all for your help so far I appreciate it!
calemasters
Allen
Springfield, Mo.
Google Search
Extreme Terrain has a consumer rating of 1.24 stars from 74 reviews indicating that most customers are generally dissatisfied with their purchases. Consumers complaining about Extreme Terrain most frequently mention customer service, wrong part and lift kit problems. Extreme Terrain ranks 319th among Auto Parts sites.
  • Haha
Reactions: GtX
calemasters
Allen
Springfield, Mo.
It is confirming that each wire in the tail light wiring harness is inserted into the correct cavity of each tail light connector for both aftermarket tail lights. Sometimes things go wrong in assembly.
JLTony
JLTony
Tony
Michigan
Oh, I gotcha. It seems to happen on the drivers side more than the passengers side. When I get a chance to take them off I'll check to compare the pins from both sides.
YippieKiYayMrFalcon
Rob
Atlanta
2021 JLU 80th Anniversary
Have you tried reaching out to the manufacturer directly? They probably won’t be able to help with a return, but may help you troubleshoot.
JLTony
JLTony
Tony
Michigan
I will give that a shot too. I asked Extreme Terrain if they could give me the contact info for them and they never replied. I'll dig around a bit and see if I can find the info
