Run it or drain it?
ajbarbier
AJ
2018 Jeep Wrangler Sport S, 3.6
Hey guys, I filled up my oil with 5qts, then added ceratec on top of that like a not super smart person. Here’s a couple stick pics of the oil level when it’s hot- gets onto the braided line. Would you drain half a qt? Or run it?
I’ve heard the horror stories
Jeep Wrangler JL Run it or drain it? IMG_2626
Jeep Wrangler JL Run it or drain it? IMG_2625
Turniipp
2021 JLUR 3.0
Drain it and don't worry about it! No need to stress about it or take a risk.
watchluvr4ever1116
Thomas
Michigan
Not gonna be a popular answer, but if it’s the 300ml size, you’re only over filling by 1/3 of a quart or so. Supposedly there’s around a +1 quart safety margin. Dealers overfill all the time if you believe what people here have said, and how many people never check their oil after leaving the dealer.
PT's19Rubi
Paul
NC - Just across river from Uwharrie trails
2019 Rubicon 2D, 3.6, 8A
Retired Electrical Design Engineer
5 quarts of oil is 4732 ml. 300 ml is 6.3% over. That's not much. And, per the following, you should be more than safe.
From internet:
"Based on designer specifications and user experiences, the 3.6L Pentastar engine is designed to handle an overfill of 1 quart (or roughly 1 liter) without immediate danger. Crankshaft aeration (crank hitting oil) typically becomes a significant risk when overfilled by more than 1.5–2.5 cm on the dipstick, often requiring 1.5 to 2+ quarts extra to cause damage."
Sandevino
North Texas
2025 Wrangler Rubicon, 2002 Wrangler X
Drain into a clean container and refill. Check the level and add as needed until full.
alphawolff
california
2021 JLU
you're fine dude, just run it. the amount of JL PUGs out there getting 6qrts every oil change is more than you'd think, and they all run just fine.
wibornz
Ted
lansing, Mi.
JL Unlimited Rubicon
This is one of those things that is an easy fix. Just make it right. You will probably be fine as many mentioned. In general a motor like th 3.6 will suffer from a down main seal if way overfilled. But that is probably not the an issue here.
Pape
Quebec
JLU Sahara
when was the oil level taken after shutdown down the engine ?
There is a specific windows to take oil level on the 3.6
ajbarbier
AJ
Probably about 5-10 minutes after. Right after shut down the oil is at the top of the cast iron, not quite reaching the the hatched
