Question about oil drain plug.
WranglerBob
Bob
Palm Bay Fl.
2023 Jeep Wrangler
I have a 2023 Jeep Wrangler V6. I am getting ready to do my first oil change does the drain plug have a gasket ? Thanks.
LazyJL
Larry
2020 Rubicon, 2001 built XJ
Retired fabricator and mechanic
jadmt
jeff
montana
STW
Utah
2022 JLR 2door 2.0T Rubicon stingrey
before you buy a Fumoto, check out the Femco, Stahlbus, and Valvomax options. They have a hose fitting that allows cleaner drain straight into a tube than I found with Fumoto. The Fumoto is great if you just want to drain straight out of the valve to a bucket, but I have found I want it to drain into a tube from the valve straight into a container. The Fumoto can do this too, if you get the longer spout and right size tube, but the Fumoto I tried didn't hold onto a tube (correct size) very securely so I had to hold it in place by hand. Not what I was looking for in a simpler, cleaner oil change. You can buy a plastic fitting for Fumoto that clips onto the spout but it's a poor fit and a pain to use. Both the Femco and Valvomax have a fitting with hose securely attached and they don't drain any oil until that fitting is screwed in. Much cleaner, simpler, and easier. You do need to keep track of that fitting/hose though, whereas the Fumoto can work fine without any fitting. After a change, I keep the cleaned fitting/hose in a baggie in the vehicle so it's always there.
Low profile may not matter if you use a skid, but a clean reliable hose connection matters even more if you have a skid installed. If you don't have a skid installed, then consider how low profile you want the drain plug to be. Fumoto has options that are more low profile than others. The Femco is offered in a very low profile version.
https://www.google.com/search?q=fem...AIgGAZAGCJIHBDEuMTKgB_ZM&sclient=gws-wiz-serp
rickinAZ
Rick
Phoenix
2026 MOAB 392
NewbJLUOwner
JLU Rubicon Diesel 2022
Installed Fumoto Valve this weekend
So far so great 👍
Looking forward to my next Oil Change 🤣
Btw- this is a 2022 JLURD 35,400 awesome miles
Jeep Wrangler JL Question about oil drain plug. 20240707_185554
Jeep Wrangler JL Question about oil drain plug. 20240707_185450
Jeep Wrangler JL Question about oil drain plug. 20240707_185351
rickinAZ
Rick
Phoenix
2026 MOAB 392
So far so great 👍
I have a half dozen EcoDiesel oil changes under my belt. Three pieces of advice:
  • Buy plastic tubing that I recommend in post #8. You can then direct oil accurately into a catch vessel. This one is the perfect capacity to drain/transport used oil to the reclaimation center (i.e. Autozone). https://www.amazon.com/gp/product/B07K1NHCHR/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
  • The filter is notoriously finicky to properly seal. Be meticulous in oiling both orings or you'll throw a low oil pressure light. If you do, remove the filter and try again.
  • Use a one gallon ziplock baggy to get under, and contain, the oil filter and you avoid slopping when you remove it. It's in an ackward place. Loosen and unscrew it, but don't remove, as you are draining through your Fumoto. That allows the excess to better drip empty. As you know, the filter is the trickiest part.
Ten minute job. With clean hands.
NewbJLUOwner
  • Use a one gallon ziplock baggy to get under, and contain, the oil filter and you avoid slopping when you remove it. It's in an ackward place. Loosen and unscrew it, but don't remove, as you are draing through your Fumoto. That allows the excess to better drip empty. As you know, the filter is the trickiest part.
thanks for tip on Oil Filter. My suggestion
unscrew the filter almost all the way out, but don't remove
Then do your Oil Change & any other services.
Then finish unscrewing, approximately 45-60 mins later
There should be ZERO drippage. Easy
Looking forward to doing next Oil Change with this fumoto
DaltonGang
Doesn't Play Well With Others
I've been using Fumoto Valves on about every vehicle I've owned, for 24 years. Excellent product. Just go with the one that is fixed in place, and has the short hose nipple attachment . This reduces how far it will hang down.
jadmt
jeff
montana
So far so great 👍
I would be putting an oil pan skid plate on that.....
henryb
henry
ga
2021 wrangler sport limited
I INSTALLED A Baxter oil adapter works great as well as a oil catch can
WranglerBob
Bob
Palm Bay Fl.
2023 Jeep Wrangler
Thankyou everyone for your replies. When I tighten the oil filter cap I am going to tighten it by hand. Then 1/8 with the socket. Seeing I don't have a torque wrench. I read to many horror stories about breaking the housing.
