Magnetic Drain Plug
DanW
Indiana
Does anybody know where I can get a magnetic oil drain plug that fits the 3.6? Thanks!
DanW
DanW
Indiana
@DanW
Dan, The oil drain plug is a M14-1.5
You can find a magnetic plug in that size most anywhere. Pick your brand... shop on eBAY, amazon, etc.
It's the same size as the JK uses..
Thanks, buddy!!
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
@DanW
Just stumbled back to this thread today...
When I posted to you in this thread, I was thinking the JL had an aluminum oil. (It does not)
Anyway, a month later I attached a 35 lb. pulling force, Rare Earth Magnet to the bottom of the metal oil pan.
I remove the magnet after the motor is off and just before dropping the oil. After oil is dropped, I replace the magnet.
I'm sure the oil plug magnet pales in comparison to the Earth Magnet in gathering up metal.
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
@DanW
Anyway, a month later I attached a 175 lb. pulling force, Rare Earth Magnet to the bottom of the metal oil pan.
Interesting.
I've got a Filtermag on mine, only because I have a 2.0L
Jeep Wrangler JL Magnetic Drain Plug 111
Rhinebeck01
Retired at 55 ..
@Arterius2
Yes, that will do. I used similar on my older JK's that had a similar metal can oil filter.
Friggin magnet thing the exact one you show, got metal fatigue.. rotted out after a bunch of years, but it did the job.
Rhinebeck01
Retired at 55 ..
Formattc
Western Missouri
2020 JLUR, Sarge Green
So, is there a reason that the magnetic plugs I'm looking at have a washer? I like this stainless steel one but they recommend changing the aluminum crush washer with each use. The stock one doesn't have a washer, but it's not magnetic either.
CarbonSteel
