Rounded/stripped drain plug
Cunky
NYC
2022 Wrangler Unlimited Willys
Hi everyone,
I was traveling and needed my oil changed so I stopped in a shop out of town. Fast forward a few months later and I'm home trying to do one on my own only to find the drain plug is completely rounded. Anyone know what the easiest/cheapest way to get that off would be?
Also, has anyone purchased a replacement plug online before? If it was successful, could you share/link it to me?
maestro5531
Paul
IL
22 HydroBlue TRX , 23 HydroBlue JL Willys
Beat a nut extractor onto the bolt and hope for the best.
azwjowner
Phoenix
And in the worst case, if vice grips, extractors, etc. don't work, you can go to a welding shop and have them weld a nut on top of the bolt, which will let you remove it.
azjl#3
North AZ
Send photo to shop that did the work, demand recompense, rate them online
Cunky
Cunky
NYC
Thanks everyone! Appreciate the help and suggestions.
J.Ferreira
Castle Rock, Colorado
www.tmgps.org
1999 Jeep XJ
wjcubellis
William
2024 Rubicon
Monkey / pipe wrench.
Also replace with a quick drain valve instead of a nut
running_man
Andy
2024 392, 2003 BMW Z4, 2012 Lexus ES350
I used a combination of vise-grips and a pipe wrench when I found the Kia dealership where I bought my Jeep had rounded it. I replaced it with one from O'Reilly's and haven't had an issue with it yet after 3 more oil changes. Best of luck!
Murphydog
Seattle
2020 X3M, 2023 JLUR XR
Never had to do this, but I would think a pipe wrench would do the trick for removing
