Wires through passenger drain plug
NewJLU2019
Curtis
2021 Rubicon Unlimited 2019 Sahara Unlimited
Question. Will they offer any protection if you end up sliding across a large rock
since they are aluminum?
donmontalvo
Don
Livingston, TX
donmontalvo.com
2021 Jeep Wrangler Unlimited Rubicon (Snazzberry)
Praetorian269
Michigan
Wrangler JL
Yup - that's AMP Research PowerSteps wiring. I did some research before having mine installed - that's how it's done.
That’s how they make it seem like an easy install. They don’t care about the problems you will have down the road.
cobra
So Ill
2021 Sahara
I don't see a problem with it. The wires under the jeep are tucked up way above the frame and coming through a rubber grommet. From there into the pass side kick panel. Mine has been fine for 3 years and i don't see a problem with a short circuit.
dpike
New Jersey
'20 JLUR 3.6
I came up through the drain plug in the back seats for the 10ga wire I ran to my dc/dc charger. I loomed it, but I'm not really that concerned with it failing for any reason. It's was one of those calls where I didn't feel like pulling apart trim to hide it in the cab and use an extra 5 or 6 feet of wire to route it decretely.
