Reducing Body Roll, Suspension?Spring?Rear Sway Bar? Air Bags?
MaggieJeep
Maggie
Melbourne, VIC
MY20 JLUR Granite Crystal
Architect
Hi all,
I have a 2020 JLUR stock suspension, stock springs with 2.5" Teraflex Performance spacer lift kit.
I have iKamper xCover RTT + Rhino Rack Backbone + Pioneer Platform + Darche 270 Eclipse Awning and other overlanding stuff.
The Jeeps' body roll is really bad even without the RTT.
Can anyone recommend an upgrade to reduce it? Springs?Suspensions?Rear Sway Bars? Air Bags?
RedundanT
So. Il
2020 JLUR
You added spacers when you should have added springs. Would look at Overland type springs designed to carry the extra weight. OME and JKS has springs designed for you application.
Jeepjunkie
Eric
Annapolis
2019 JLU Sport
MaggieJeep
Maggie
Melbourne, VIC
Architect
I added spacers to my Jeep to lift it when I first got into off-roading. After doing it so often, I fell in love with it and even more in love with over landing hence the upgrade. It’s a step by step process of falling in love with the sport and upgrading as I didn’t know much about Jeep and it’s sport previously
I had increased lean and what I would describe as a squirming under acceleration when I lifted my JL by 2.5+ inches.
I improved the roll center of the rear suspension and that helped my JL a great deal. I used a synergy brace:
https://www.synergymfg.com/synergy-jeep-jl-jlu-rear-track-bar-relocation-bracket.html
mine is not an overlanding rig, so YMMV
I’ll take a look. Thanks mate.
RedundanT
So. Il
2020 JLUR
No worries. Old Man Emu/ARB springs be available in your area I would reckon.
AnnDee4444
'18 JLR 2.0
+1 for fixing the roll center. The distance between the center of gravity and your roll center is now 2.5" longer than OEM, meaning that the weight of the vehicle essentially has a 2.5" longer lever arm to cause body roll. There are only two ways to shorten this lever arm: raise the roll center or lower the center of gravity.
Adding the Synergy track bar bracket posted earlier will help. Since it raises one side 3.25", the resulting roll center will be 1.625" higher. Ideally you would be able to raise the roll center 2.5", but I doubt a 5" tall bracket would fit (and nobody makes one).
MaggieJeep
Maggie
Melbourne, VIC
Architect
their products have an up to 25% markup. I dont know why it’s more expensive in AU
Jeep Wrangler JL Reducing Body Roll, Suspension?Spring?Rear Sway Bar? Air Bags? rear_suspension_design-panhard_bar-
will not work as I am RHD. I need RHD specific
AnnDee4444
'18 JLR 2.0
The track bar is different on RHD? If so, please share a photo so that I can compare to LHD.
Jeep Wrangler JL Reducing Body Roll, Suspension?Spring?Rear Sway Bar? Air Bags? 20180205120126-55079e43
Glamisfan
SoCal, 30 minutes from Glamis
2020 Sting-Gray JLUR
I never thought of that before, but I bet it is reversed. The front track bar Has to be parallel with the Drag link from the steering box, the steering box is on the right hand side so it makes sense the front is reversed. So of course they would reverse the rear one also.
AnnDee4444
'18 JLR 2.0
That's a good point...
I can't think of any particular reason why the rear would have to be mirrored, but that doesn't mean they didn't do it.
MaggieJeep
Maggie
Melbourne, VIC
Architect
If i could get a RHD Track Bar bracket, I would, but we don't have any. The track bar is not flipped but the bracket is.
I just purchased a beefier swaybar from Whiteline so we'll see how that goes.
But I reckon i'll get a coil spring upgrade, shocks and maybe airbag.
Just need some recommendations.
LowBama
Adam
Mobile
Silver JL
Engineer
Can I install a track bar bracket and an adjustable track bar? This way you get the added benefit of lower roll center and stiffer bar. I only have terraflex 2” spacer in front a 1” in back on a JL Rubi
MaggieJeep
Maggie
Melbourne, VIC
Architect
Don't hijack my thread man T_T
But yes, technically you are supposed to install both but depending on the lift, you can get away with bracket only.
But you have a 2" and 1" you don't really need to change the trackbar geo as it's not noticeable on a small lift.
MaggieJeep
Maggie
Melbourne, VIC
Architect
spoke to OME ARB. They only have 3.5”. 2.5” will be next year. You reckon they’d be out in the first year the JL was out... it’s been 2 years since the release of the JL and they’re still not ready. *facepalm*
