fuelfox4949
i have a 2 dr rubicon with rock krawler 2.5 inch lift
so i got back from moab and when i was there with my tool box and cooler in the back of the jeep i was bottoming out fairly easy, i found i only had 3 inches between jounce and bumpstops.
so i just installed a 3.5 inch triple rate spring for the rear of my jeep and left the front 2.5 in simply because i like to have some rake so when i put my gear in it will level out.
1. while looking at the rear swaybars they are 11 inch eye to eye and they are close to the axle tube however i have the pinion set as far forward as i can to put space in between the link and axle tube, the rk instructions say you should have a adjustable link set to 12 or 13 inches. if i get a longer link that pushes the bar up will it push it away from the axle tube or closer?
2. i have not adjusted the driveshaft yet cause i am getting conflicting answers on what degree the zperra joint should be at. i have a angle finder on the driveshaft and it was 17 degrees then the angle finder on the rear pinion is 7 degrees. wondering if that is acceptable? if i push the pinion up to get to 15 degrees i.e 2 degrees below that would push the swaybar link into the axle tube.
3. i have the arms adjusted to what rk suggested however i had to move the upper in closer to get the springs to stop bowing so much.
i know this post is a bit all over and i am just trying to get some ideas where to start tackling the adjustments, i will be posting pictures right after i post this thread.
my idea is get longer sway links to push the sway bar up and possibly that will get it away from the axle tube however i seen there is scratches on my frame rail from the bolt on the link hitting the frame rail so i would think longer links will make it hit more often.
