Rear Reverse Lights
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
2019 Jeep Wrangler JL
Automotive LED Manufacturing
Just wanted to pop in here in case someone stumbles onto this thread. An option for this is available on our website now! Pre-order today :)
Jeep Wrangler JL Rear Reverse Lights JL-Reverse-3
Mikeyut3
2020 JLUR
BTW - Does this install require bumper removal? Thx.
Mikeyut3
2020 JLUR
ORACLElights
Metairie, LA
Sorry for the late reply- we are still working on installation video, I can confirm and get back with you!
Chocolate Thunder
Jeremy
If you could also take some good before/after photos and/or videos of light output with them installed outside in the dark that would help a lot.
ORACLElights
Metairie, LA
Certainly! I will let the R&D Team know!
JeepAustinWeird
Austin, Texas
2018 JLU Rubicon
Are you able to confirm whether bumper removal for installation is required?
Also any likelihood for these lights to throw or trigger any error codes or warnings?
Thanks
ORACLElights
Metairie, LA
Thanks
If you have a trailer hitch it is suggested to remove the bumper to make installation easier.
No, we have not seen any codes or warnings after installing these lights.
Mikepa
Massachusetts
'18 JLUR, '11 LR4, '21 F-150 FX4, '08 620i Gator
Trying to install mine at the moment. Passenger side went in with a snap. Driver's side, however, doesn't want to go. The Oracle's top width/shape is wider than OE reflector as you can see. I do not want to force it as the light will give before the steel bumper does. Anyone else see this?
Not sure the bumper opening can be spread but will give it a shot or two with persuader.
Update: gave opening corner and side a few solid shots with socket extension and hammer and managed to get it on. Time for a like touchup paint.
Jeep Wrangler JL Rear Reverse Lights B0372962-6832-47D4-92AC-9FB08766424E
Jeep Wrangler JL Rear Reverse Lights A8DC2685-8B47-40E7-9885-B911314567C3
Jeep Wrangler JL Rear Reverse Lights 354A9B6B-2398-4AFD-9B27-EFAD60BD9FBF
MauiSteve
Stephen Rodgers
2021 Rubicon 2 door, 2018 Colorado ZR2, 2009 Honda Ruckus, 1973 Honda CB750
Mostly retired
Where do these connect?
Windshieldfarmer
Randy
Wichita, Ks
2015 JKU, 2020 JlU on order
I had this issue also - I put lubricant on the metal bumper where they were hanging up and gave the lights a solid hit with my palm....they snapped in.
klhjeep2018
Harpers Ferry, WV
2018 Rubicon JL
Sales manager
I had the exact same issue. Palm of my hand as well I was worried about the light cracking but so far so good.
Mikepa
Massachusetts
I tried to get mine in using soapy water but it was not going and I was concerned about damaging the seal around the new light by hitting it hard. As it turned out, drivers side looks good BUT the passenger side, which snapped in easily, is fogged up. Sadly, it had only seen one water event and that was me washing the rig by hand, no power washer.
ORACLElights
Metairie, LA
Hey Mike, can you DM us a photo of the condensation and your order number for our product team to look into?
