JL: Rear Turn Signal & Reverse Light Bulbs!
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
2019 Jeep Wrangler JL
Automotive LED Manufacturing
Give your Jeep's rear a lift :angel: with these OEM replacement bulbs for the JL !
REVERSE LIGHT BULBS for JL (PAIR)
These new bulbs from ORACLE Lighting feature High-Powered 5 Watt CREE XPE LED Chips. The new 5W XPE replaced the famous CREE XRE chip earlier this year, featuring even more lumens! These are lightweight, heavy duty direct OEM replacement bulbs with easy installation. 5133-001
TAIL LIGHT / REAR TURN SIGNAL BULB (SINGLE) FOR JL
The ORACLE line of SMD replacement bulbs features an unsurpassed level of brightness and quality. This bulb utilizes 5050 SMD technology which produces vibrant light with sharp hues while consuming only 1/10th of the power of the factory bulb. These 5050 SMD chips are rated at 100,000 hours for continuous use. (Lumen Count = 270-306lm) Turn signal SMD bulbs will require the use of a "Load Equalizer" in order to prevent "rapid-flash". If using this bulb in brake light, reverse light, running light, etc you will not need to add a Load Equalizer. SMDs increase safety when used in tail lights because they illuminate faster than incandescent bulbs.
Cntr78
NJ
2021 JLU
Jeep Wrangler JL JL: Rear Turn Signal & Reverse Light Bulbs! 5103_turn_signal_a496701a-e35b-4f25-8b58-851ef0f05561_1024x1024
For the taillight/turn signal, are the load equalizers and t-taps included?
It does not mention them in the product description, but the install video shows them being installed as if they come in the kit with the light.
ORACLElights
ORACLElights
Metairie, LA
The load equalizers are sold separately and can be found here.
