Rear defroster problems
DaltonGang
Doesn't Play Well With Others
The dealership tried to solder it 3 times, and the longest it lasted was 2 days. The shortest was before I was finished inspecting it, after they fixed it, at the dealership.
They gave up, and replaced the window. That was a couple of years ago. Still going strong. But, I am somewhat hesitant to use it. I'm thinking the glue, from the factory doesn't do well with the heat.
morzh
morzh
Jackson NJ
2009 Jeep Grand Cherokee, Wrangler JLU Rubicon
Electronics Engineer
The (interim?) end of this episode.
I brought the Jeep to the dealership Tuesday morning and picked it up only now, about 12pm Saturday.
They replaced the whole wire harness on the drivers's side (yes the Common was missing). They have not figured out what was wrong, as they found no faults in the harness itself after having it removed. Plus when disconnecting the button contact, the pad came off (as I expected, this is why I did not touch it) and they had to re-epoxy it also, same as the passender side one.
I wanted to have the harness to diagnose it myself, but they said they need to send it back for warranty purposes.
So, the silver lining is, it works (according to them) and the extended warranty paid 100% after going back and forth (I suspect that was part of the delay).
swmartin
Massachusetts
2018 Jeep Wrangler JLU Rubicon
This has been happening to me since I bought my Rubicon in 2018. It's now happened to me 7 times. Out of the 7 times they replaced the glass 3 times and it falls off 2-4 weeks later. It's clearly a flawed design on the 2018 and up jeeps. I've been fighting with Chrysler for months because they keep charging me deductibles. The only way they will service this as recalls is if everyone starts open Chrysler service tickets. Lets get it started. This will be my last Jeep if they don't recall it and keep giving me the run around This is my 2nd wrangler and a grand Cherokee in the past - Never had this problem with any of the others.
The best part is, when I told the Chrysler lady this is known big issue sine they released the JL, she told me she doesn't believe anything on these threads. She'll believe it when Chrysler does a recall. Great customer service over at Chrysler.
morzh
morzh
Jackson NJ
Well, let's get it started then.
Do you know the process?
I do not pay deductibles as the insurance was sold to me with the promise that if it is serviced in this dealership, they will absorb the deductible. But I'd rather they remedy it once and for all.
I have my Grand Crerokee 2009, this is not an issue with it (well, many others, but not this).
When I bought my first, a Cherokee 1992 model, this was a problem, but I was not sure if it wasn't a result of some other damage. I soldered it myself and it held for a few years, then I resoldered it again.
So, again: if you know how to start it, and I hope those who've read it and had similar issue join it, maybe we can make Chrysler to recall it.
Willys_Wonka
PA
JLUW
The conclusion (and hopefully the end) of this story: I went to my dealership and they fixed it. Yes, for free! The extended warranty took care of it. To my question "how much I would have to pay to do it here, were it not for the extended warranty" the answer was "about $200". Well, the price I'd pay for the kit and the trouble of doing it in the winter by myself.....yes, it took 2-1/2 hrs of which 2 hrs was getting the warranty approval (I have Zurich), 10 minutes check-in and 20 minutes the repair itself. I am not going to complain.
And, yes, they do not solder, they also use metal epoxy. I guess the soldering is only possible at the factory (and they, obviously, at least at Chrysler, do not achieve stellar results in doing so). Being and electronics man myself, I think soldering would take pre-heating the whole glass pane, so not to create local stresses in the glass when soldering, and then use some soldering paste and a heat gun, to do it properly. And it would take me, with preparation and during good weather, at least as much time as it took to visit the dealership.
How is your experience with Zurich warranty coverage? I’m considering it once my 3-year basic is up.
morzh
morzh
Jackson NJ
I would noyt call it "experience" just yet.
I used it twice, both time towards the rear defroster.
One time I tried to use it but it explicitly states it does not cover leaks, so I had no case. Even though it was internal gasket to the b ody of teh car that leaked.
So read it carefully. It is not a bad insurance, and sop far I am sure I've saved maybe 500 to 700 dollars due to it. Also when you buy it through a dealer and go to that same dealer for the service, they will wave the $100 per repair deductible.
The car is nearing 4 years, so I guess this is the beginning of that time when it will want to visit the shop more and more (m,y experiwence with Jeeps so far).
Also assess your years/mileage. If it is your primary car and you exhaust your 100K miles fast, it might not pay for itself. I literally was barely useing it the first 3 years (used it 50/50 with the old car for 1/2 year and then the pandemic, so I worked from home 80% to 95% of the time; all in all I put 7K miles on it in 3 years; this will help with stretching the insurance term).
It is not the cheapes either. But up 'till now I canno say anything bad. In the next 2-3 years, as it starts the usual "Chrysler" thing, I will probably gain more experience with it.
Willys_Wonka
PA
JLUW
Great info, thanks! I’m also considering the Mopar Max Care.
JeepinJason33
Denver
Mine has been broken for a couple of years now. Can't really see out the rear with the spare there anyway. Since I bought one of those rear view mirror camera's, I never have to look at the window anymore. Seems like it might be a better fix for those that are having issues with it.
morzh
morzh
Jackson NJ
To me the cam is not a 100% sub for the rear mirror. When I try using it to back out of my fairly longh and curve driveway with a sizeable maple at the end, I end up going close to the trunk and certainly into the branches. The cam distorts the view. It is a safety device, but not a real "real view" thing, even though it does show those "directing lines". I still turn when going backm same as i always look back when changing alnes, despite having the sensors and "dead zone" indicators.
So....if it works for you, great. Myself, I want my car to have everything in order. Especially when it comes to viewing things.
JeepinJason33
Denver
I understand on wanting everything to work. The mirror cam can be set to whatever position you want and compliments the factory rear camera really well. I have a much better line of sight than I had before.
morzh
morzh
Jackson NJ
I hate this but I have to append what seems to have become a recurring story and has the potential of becoming a real epopee.
The defogger broke again. It took it 3 or so months to separate again, but I noticed it when I needed it, which is in November. The dealership has 2 months wait to take any service in, and the Zurich extended wareranty is unreacheable. My car has spend 2 days in the dealership which was supposed to clear it with Zurtich but did not, and so they were unprepared. I am picking it up unrepaired only to bring it back later. Each time it takes me 1/2 day off work, and so it does my wife who has to drive me.
And what's worse, the rear glass is defective, as the contacts are part of it. But they are not willing to replace the glass and only want the contact re-attached, which will fall of in 1/2 year max.
Other crappy parts have been detected: while driving there yesterday, my visor fell out. This left pivot pin simply fell out of the socket.
What a piece of crap, pardon my French.
I have been a proponent and a follower of "buy American". Despirte owning 2 Jeeps before. I thought that maybe Rubicon, the flagman and a very expensive truck, would be built at least half-right. But it is not.
Owning any Chrysler product is the best cure of stupid idealism and "buy American" folly.
Buy What Is Good! We, Amnericans, make crap, and more so with each passing year.
PS. And, yes. I-Phone is built in China.
d k
Portland, OR
FJ Cruiser
Technician, engineer, home builder (wannabe), insurance, wealth management/retirement advisor
Horrible warranty. Do not get Zurich. Its the same company that owns Farmers. Not good at all
FLTrailRider
2021 Rubicon 2dr
I just got this problem where the wire has broken.
The warentee company only wants to pay for the TSB to glue the wire back on , which does not work
TSB is 23-089-23 with 0.3 hrs labor
Dealer refuses to do it as it fails and wants the warranty company to replace the rear glass with defroster.
Defoster is under warranty.
Rear Glass is not.
but they are attached and when they warranty claim the part it pulls up the part # it says "glass" which is not under warranty.
Thoughts?
morzh
morzh
Jackson NJ
Well, that to me is not obvious.
So far they have paid for everything that they said they would cover.
And. They have since changed the real glass twice ($870 a pop) and paid it all.
morzh
morzh
Jackson NJ
The continuation of the story:
So the insurance admitted this is not a broken glass but the defogger, and the glass has to go and be replaced, so they paid for it. The story though dragged for a year.
First they ordered the glass but then Chrysler changed the glass vendor and so they could not procure it. The glass came about end of June 2025.
But then I was away (had to go to FL 3/2025 to care for my mom for 4 month altogether) so the dealer agreed to wait 'till 9/2025 to install the glass.
So, closer to the end of 9/2025 the glass was installed. closer to the end of 12/2025 after just one use the contact fell off again.
The dealer saw me end of Jan (this is good; their waiting time is between 1 and 2 months), ordered the glass again (they also said, the way it fel off, they could not glue it)!The glass came 4 weeks ago, but the snowfall kept them from coming to work (and leaving me no warning until after I came). Another 2 weeks. So, a week ago, 3/12/2026, they installed the third glass (counting from the original).
I thought about it. And then thought some more.
Problem #1. They tie the wire that keeps falling off (the other, the driver's side, which is short and has no service loop, holds fine) to the washing fluid hose. To me, a bad idea. The rubber hose bounces a lot, and wiggles the wire, which is being held by one cable mount (close to the snap contact), which does not really immobilize the wire at all, just does not let it hang.
So I installed two adhesive tie-wrap bases and tied the wire with the tie-wraps.
Problem #2. But then something about the way the solder looked at the contact kept bugging me. It looks shiny and smooth, and were it broken off, it should look greyish matte not smooth.
So this morning when I remotely started the car (the morning was cold and the defogger was auto-turned on), after 4 minutes I touched the snap contact. I nearly got burnt.
Plus to that, that contact is loose and freely rotates around the part that is soldered to the glass.
Plus to that, and I noticed that before but attributed it to the company's bad quality, the wire insulation closer to teh contact looks as it was burnt/melted.
I think, the bad connection results on power loss right inside the snap contact, which heats up, and coupled with vibration just detaches itself. Therte could be good 20-40W loss on it if it is mere 0.1 Ohm.
So, the darn techs who install the glass, do not bother looking at the wire and the contact.
I called them today.
I could try to unsnap the contact and bend it into the snapping, but I am afrait it's been annealed, having lost it spring action, and won't hold for long.
So....there we are.
