Rear defroster problems
morzh
Jackson NJ
2009 Jeep Grand Cherokee, Wrangler JLU Rubicon
Electronics Engineer
I do onot know how common they are. I suspect they could be.
Just as my 3 years have passed (was i smart having bought an extended warranty, or what....having experience with famous Jeep reliability, I thought I had to) I found my rear defroster was not working. Unfortunately it only manifested itself when we had freezing temps which came after my regular warranty had just expired.
I started with the fuse which was OK. Today, armed with a DMM, a screwdriver and pliers, I went to investigate further, but it became a very short investigation, as as soon as I looked at the harness, I found the passenger side defroster wire, that comes to the glass, hanging loose, the solder connection between the fastener contact and the solder pad on the glass being broken. Funny thing is, the solder looks shiny and smooth which is not how a usual broken solder would look. Almost as if it heated up and desoldered itself. Except there is nothing to short there, and the fuse is OK.
I would even cancel the appointment and solder it myself, but with cold temps outside and lack of a larger than a lab Weller 40W iron, I doubt I could do a good job soldering it back in place. My extended should cover everything so, I hope, they will fix it.
How many of you have experienced defroister issues? I ifound several complaints.
martoaj
NYC
2022 Wrangler Sahara 4XE
This 29 page thread of people with the exact problem would indeed confirm "it's not just you"
I'm having mine fixed in a couple days. Fully expect it'll fall off again by next winter ?
BXFXJeep
Toronto, ON
2021 4xe Sahara
Same thing happened with my 2018 JL, I was going to trade it in shortly, so I left it as is.
Dan M.
Albany NY
2020 sport (2 door)
It is fairly common. ALso, there are reports of people trying to fix it themselves and the rear window shattering when they turn on the defroster. If you have the extended warranty, let the dealer mess with it.
morzh
morzh
Jackson NJ
Agree. I am sure they tried soldering, and created local stresses in glass.
Adhesive won't do it, but then is not as reliable as good solder (I am sure this is bad solder).
Soldering on glass requires preheating much larger area around it, and it is hard, especially during winter.
morzh
morzh
Jackson NJ
58Willys
Geoff
Western Washington
2018 JL Sport
Loctite Abelstik 3888, is an electrically conductive epoxy. I used it to fix my broken defroster wire.
morzh
morzh
Jackson NJ
The conclusion (and hopefully the end) of this story: I went to my dealership and they fixed it. Yes, for free! The extended warranty took care of it. To my question "how much I would have to pay to do it here, were it not for the extended warranty" the answer was "about $200". Well, the price I'd pay for the kit and the trouble of doing it in the winter by myself.....yes, it took 2-1/2 hrs of which 2 hrs was getting the warranty approval (I have Zurich), 10 minutes check-in and 20 minutes the repair itself. I am not going to complain.
And, yes, they do not solder, they also use metal epoxy. I guess the soldering is only possible at the factory (and they, obviously, at least at Chrysler, do not achieve stellar results in doing so). Being and electronics man myself, I think soldering would take pre-heating the whole glass pane, so not to create local stresses in the glass when soldering, and then use some soldering paste and a heat gun, to do it properly. And it would take me, with preparation and during good weather, at least as much time as it took to visit the dealership.
TXWRANGLER20
Fred
Copperas Cove, Texas
2020 JL Wrangler Unlimited Rubicon
I had the same thing happen on my 2020, the dealer did fix it and so far, it is holding up.
OldBlue
Doug
Chatham Twp, OH
See my Signature
Aerospace Forgings Test Lab
morzh
morzh
Jackson NJ
37" tires.
Oh that....well....my purpose is to see the tree that I have to not to drive into, when backing up (I do not trust the rear cam). That tree can be viewed with pretty much any size tires, even the quarry truck ones.
morzh
morzh
Jackson NJ
Well, it is not working again. 1-1/2 month later. A frosted window, and no defrosting.
The wires seem to be attached.
I took the meter, started the car, turned the RWD on and put the leads on the exposed metal pads near the button contacts. There were some scratched places from the shop prepping them for epoxy application, so there shouldn't've been any bad connection to the leads.
The meter showed exactly 0V. I had the meter on the DC volts.
I checked the fuse (#81) - it is good.
My insurance explicitly says the RWD is covered, so it still should be free for me, but trips to the dealership are a nuisance.
Any other place I should check? A relay perhaps? I am willing only put so much effort into it, considering the service will be free, but still....
OldBlue
Doug
Chatham Twp, OH
See my Signature
That's good to know, I'll have to try it. Rear window was replaced on the wife's JLU shortly after purchase for the same issue. It's broken off again, and since it's out of warranty, maybe this epoxy will do the trick.
morzh
morzh
Jackson NJ
Well, checked once more. The resistance to GND of the heat grid is 5 ohms on one side and 4 ohms on the other, so the resistance of the grid is 1 Ohm.
The voltage is applied, it is 14.5V. So it is about 180W heater. But. It is exact same Voltage (to a millivolt) on both ends. My feeling is, the GND wire is open.
And there could be a reson for it: when I repaired it the 1st time, then in 2 weeks I had to go for a leak repair, and they had to lift the roof or part of it, and the GND wire goes in it. I wonder if the "water doctor" unmated the connector and forgot to re-mate it.
