Radio Reception Issues
Jerpy
2021 JLU Rubicon
Ever since I've had my Jeep my only gripe has been with loss of radio reception anytime I drive under an overpass or enter a parking structure. This was never an issue in any previous vehicle I've owned. Is there anything that I can add/mod to combat this problem?
I wasn't able to find any other threads on this, so if it has been addressed elsewhere I'm hoping someone can point me in the right direction.
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
Radio or Sirius? Sirius is, for all intents and purposes, line of sight. Radio however, you shouldn't be losing signal that quickly from going under an over pass. To be honest, even in underground parking, unless you're talking Cheyenne Mountain, it should keep a signal.
Jerpy
Jerpy
2021 JLU Rubicon
I'm aware of the issue with satellite radio, but I'm talking about regular AM/FM.
mtbjeep
MA
2018 JLUS
Stock antenna or stubby?
SnowyJeep
Canada
2020 Jeep JLU Sport S
Strange, I don't think this is a common issue. My Jeep with a stock antenna can still get signal two underground parking levels down.
OldBlue
Doug
Chatham Twp, OH
See my Signature
Aerospace Forgings Test Lab
Even w/ a stubby antenna, my AM/FM reception is still decent.
Reinen
2021 Jeep Wrangler JL Rubicon
First of all, if you have a stubby antenna your ability to tune in weak stations will be significantly compromised. That's regardless of how good the the stubby antenna is (it's a matter of physics). The first place you'd notice that is in the situations you describe.
If you don't have a stubby antenna and you're not way out in the boonies, it sounds like a bad antenna connection. Take your antenna off and make sure the connection is clean. If it's not that then it may be the cable between the antenna and radio, in which case you're probably best off taking it to a dealer for warrantee repair.
Powelligator
Parker, CO
2006 LJ Rubicon, 2022 JL Rubicon
It's always been common to lose AM when under an overpass or a parking garage, FM generally still works. Satellite is the same, as above, needs line of sight to the south sky.
Bswift60
Bob
Arkansas
2018 Wrangler JL
I have a 2018 JL with the same type issue. On AM or FM, it sounds like it's not picking up the stations well and volume will not go up. Turn it all off and back on, will sometimes fix it. This is very intermittent, but very anoying. Does not happen when using bluetooth or usb. Just the AM/FM. Replaced antenna, mout and cable, Nothing helps. Maybe there's an issue with the unit itself?
