Terrible Radio Reception
themattparty
Houston
2018 JLU Rubicon
Just wondering if this is a common occurrence or just an issue with my JLU, but ever since I have owned my new Rubicon I have had TERRIBLE radio reception. I realize that a large amount of people will just use Carplay or Bluetooth for music...but sometimes I take a quick trip and forget my phone or just want to listen to the radio. Extremely static/white noise/terrible reception for nearly every station. Also, I live in Houston, TX so its a major city, i'm not in the middle of the wilderness.
Anyone else? Potential fix?
obwahn
Retired puter dork
Assume you are not talking SXM?
themattparty
themattparty
Houston
2018 JLU Rubicon
  • Thread starter
  • Thread Starter
  • #3
I meant FM/AM. Sorry, should have stated that in the post. Sat Radio works fine. Also have checked the antenna and its connected fine no problem. Wondering if there may be a wiring issue. Just wanted to see if anyone else had come across this issue yet.
jroman
Jorge
Chicago, IL
2018 Jeep Wrangler JLU Sahara (Granite)
BCBA
If this hasn't happened with your previous cars, then it must be the antenna or wiring. Mine has been crispy clear on all AM, FM, SXM. Maybe try getting one of those aftermarket antennas before looking into the wiring?
bjeep1983
Northampton, PA
2018 Wrangler Unlimited JL Rubicon
I haven’t used AM/FM a lot but my Sirius cuts out. They sent me a link to refresh on my own but doesn’t seem to work.
Skippy
Aaron
Minnesota
2018 JLUR, 1996 Ford Bronco 351W
I actually got a shorter black antenna on mine and still never have the issues like you mentioned. I would probably bring it in since I rarely use satellite or bluetooth or carplay or anything else. I wish these had cd players...
W5MQS
Mitch
Temple, Texas
2018 Granite Wrangler Rubicon JLU; 2020 Mercedes GLB 250; 2013 Red Ford F-150 4x4
Interventional Cardiology
I believe the regular radio is an HD radio? Someone correct me if I'm wrong on that...or maybe that is only if you upgrade the package to the "infotainment package'.
themattparty
themattparty
Houston
2018 JLU Rubicon
  • Thread starter
  • Thread Starter
  • #8
There is an option on the screen for “HD” however I’ve not noticed a difference when turning it off and on.
It has to be a wiring issue, just today I tuned through all FM channels and was lucky to hear anything besides static. I will contact Jeep to see if anyone else has reported a similar issue.
Scott1911
Oklahoma
JL 2 Door Unicorn
Check how tight your antenna is screwed into the mount. Might not have been tightened.
Grimm_E
Maryland
2018 Wrangler JL Unlimited Rubicon
I have not had any problems with the radio at all. But I agree with others on the thread, that you should check the antenna to make sure it is not loose.
Hootbro
Don
Delaware
2018 JLU Sport, 2020 JT Rubicon
Mine was delivered with the antenna disconnected at the right lower kick panel were the antenna comes into the cab. Never noticed it for a couple of days as I almost use SXM exclusively. Also found some assembly trash with a plastic bag stuck behind the glove box when I was troubleshooting this.
themattparty
themattparty
Houston
2018 JLU Rubicon
  • Thread starter
  • Thread Starter
  • #13
That would make sense for my issue. Thanks for the info! Will give it a look. Fingers crossed that solves my problem!
Newbiejeeperjl
Unlimited JL
I totally agree with you. I live 30 min from downtown Dallas and I can barely get reception on my radio. If you fix the issue. Please let me know.
Hootbro
Don
Delaware
My advice is to drop the glove box down and out. Reach inside and feel for where the antenna base come through the right fender into the cab and feel for the pig tail and follow it down for about 12" or so and it should have a connection point right below the glove box by the kick panel and that goes to the back of your radio from there.
In my case, that antenna cable between the back of the radio to the antenna pigtail connection is wrapped into a wire harness and is somewhat banjo'd at that first connection point off the antenna pigtail. It was a pain to get back connected.
Diode Dynamics
