Terrible Radio reception
Kevman3
Kevin
New Jersey
2024 Jeep Wrangler 4xe High Altitude
2024 wrangler High Altitude xle. Great so far. Only problem is bad radio reception. AM is all static, cant listen to a ballgame. Any ideas?
dapipp
NW Idaho
2006 TJ, 2006 LJ, 2019 JLR, 2024 JLUR
Or maybe the fact that the antenna is buried in the windshield and only works well when you are heading towards the radio tower is the issue.
hoch
Hoch
UT
2018 JLUR 6-sp
I didn’t know the new ones did away with the whip antenna… šŸ˜•
I’m old school and still like listening to AM/FM. I have noticed I get way better reception in my Jeep than my Toyota which has no external antenna.
Kevman3
Kevin
New Jersey
I live near NYC, and on all cars reception is great. On the 24 Wrangler antenna is in the windshield. The AM radio sounds like my dads 76 VW Rabbit used to sound, all static. FM not great but its OK. Happens on electric and ICE. Strangely when you put it in park only, static goes away.
Kevman3
Kevin
New Jersey
Just to listen to sports mostly....old school.
Aussicon
Cape Cod via Australia & N.Z
2021 JL Rubicon Unlimited
Get a Sirius subscription.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
Unfortunately, the investment in conventional radio is dying. The market is shrinking all the time and the manufacturers don't want to invest money in features fewer people are using. So radio reception is a low priority for them.
That being said, there could be a legitimate problem with the wiring in your Jeep. Could be a pinched wire or bad connection. Might be worth taking it to the dealer.
Gtbullet
Greg
pa
2024 Rubicon
Sometimes, the ground on the radio isn't good and you here the motor though you,re radio. In your case maybe the electric motor. My 2015 jk had terrible AM radio reception with lots of static.
If the jeep is new and still under warranty take it to the dealer, if not check the ground on the radio and make sure you have a solid ground connection. In some extreme instances they Install an inline what they call an electrical filter. This should also help with the static..
Kevman3
Kevin
New Jersey
Thanks, check that a ground wire is connected to the back of the radio?
Gtbullet
Greg
pa
2024 Rubicon
Yes and check to make sure the ground coming from the radio has a good connection to the frame of the vehicle..
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
When driving away from the dealership in my brand new 2020 JLUR I realized that the radio reception was horrible. I turned around and had them fix it. It was a loose wire.
Add it to your list of things that the dealership needs to fix on your next visit.
hamiamham69
Nantucket MA
2019 Unlimited Sport
If you need a quick fix and do have good cellular reception you can download a radio app from the App Store. AM radio does seem to be going the way of the Dodo bird. That being said unless you’re in a valley somewhere in rural NJ you should be getting some reception. If NONE of the AM stations come in then o would blame it on the Jeep and check the physically connections between the radio and the antenna. If, on the other hand, you are getting some and not getting others I would say the Jeep is ok and maybe some sort of specialized antenna is needed to get those weka stations
Richard
Jeep Wrangler 2020 JL
I’ve never gotten good radio reception on both my previous Jk and now my JL. Perhaps it’s due to changing the antenna to a short stubby one.
Kevman3
Kevin
New Jersey
Thanks for all the replies. I get reception, just loaded with static. Maybe on next oil change i will take it to the dealer and have them look at it. Not in the mood to take the dashboard apart to get behind the radio in this weather. Strangely when in park only, the static goes away.
